Old 12-13-21, 01:02 PM   #1
dguzzi
Default Compressed air dryer
Does anyone have ideas for an airline drier that might work as good or better than an inline type?
dguzzi is offline   Reply With Quote
Old 12-13-21, 10:29 PM   #2
You can take copper pipe and loop it with dog legs with drain valves it helps alot.
I run that into my dryer. Auto drain on the compressor helps alot.
I plasma cut and sandblast/powder coat so I need really dry air.
ID:	9405   Click image for larger version
Daox (12-14-21)
Old 12-14-21, 11:50 AM   #3
dguzzi
I found a video on making a drier from a water filter vessel. I'll try that since I have one laying around anyway. Thanks for all the ideas!
Old 12-14-21, 12:18 PM   #4
Be carful if it is plastic or has PVC it can explode sending shrapnel like particles
