Old 05-31-20, 11:02 PM   #1
Default Interesting new take on a window A/C
About the only features that seem to be missing are heat pump operation and infrared tracking to automatically direct airflow where needed.
Daox (09-18-20)
Old 07-14-20, 04:38 PM   #2
AirConditioner
That's interesting, though how many kilo-dollars does it cost? Amazon has some real mini splits just over $600 these days.
I've always wanted to see a dual hose style "portable" heat pump that you put outside on the ground, rather that having the compressor and fan motor inside or hanging from the window. Seems like the guts of a normal unit would work, just needs a case designed for outdoors.
AirConditioner is offline   Reply With Quote
Old 09-17-20, 07:55 PM   #3
launboy
Quick search on amazon says they can be picked up under $400. So awesome to see this tech being brought into the window shaker space. Cost less than a mini and the big thing for regular folks, no installation/lineset to manage. Heating mode would be icing on the cake.
Old 09-18-20, 01:45 PM   #4
I'm curious about the infrared tracking on units similar to this one. If you have one of these in a kitchen and have a crock pot or a full hot dinner spread with a dozen of the family over. ..or if it's in a bedroom and you have a hot cup of coffee, do these units start cooling the occupants, perhaps more than desired due to the unit not knowing what the heat source really is and over compensating? I'd almost not want this type of system outside of a living space or a bedroom. In a bedroom, I'd almost always just want the unit to always blow the air towards the bed.
Old 09-18-20, 11:21 PM   #5
The mini splits with that feature are quite sophisticated, with a low resolution thermal IR sensor array, high resolution near IR sensor array, and an embedded Linux processor of similar compute power as a Raspberry Pi.
My wild guess as for what they're doing in the algorithms is that they look not only at temperature but also the size and shape of the hotspots and whether or not they move.
