Old 03-23-20, 12:22 PM   #1
Default Harbor Freight sandblast cabinet heavily modify.
I needed a sandblast cabinet but did not want to spend a bunch of money. I still needed it to work well.
I did some research. The are many videos with mods out there. lots of helpful ones.
Someone sells a kit with the upgrades but that was to expensive for me but those upgrades are very good. I just rolled my own as many other have done.
https://www.harborfreight.com/abrasi...net-68893.html
https://www.harborfreight.com/5000-l...dia-61870.html
I used just about a whole tube Polyurethane adhesive to seal the bottom.
You do not want to use silicone caulking if you are going to be powder coating.
I removed all the foam that came on it everywhere except the door and the top glass.
I bought glass a lowe’s 24” x 36” and will cut it into 3 pieces. Under $15 This will replace the plexiglass this gets all scratched up.
I used a roll 3M VHB Waterproof Foam Tape for all seams in the top.
I closed off the top back baffle. (that will now be the air in let.)
I added a side baffle. That will now be the vacuum outlet.
I added foam insulation between the bottom and the top.
I am adding DIY metering on the bottom. Made from PVC and black iron at the top.
I cut the bottom tray you put the parts on to allow more room in the cab.
I added Eastwood foot peddle and nozzle.
https://www.eastwood.com/eastwood-bl...l-and-gun.html
I bought replacement hose at lowes for the media hose as Eastwoods was too short.
I bought something similar to dust deputy for my shop vac on amazon.
https://www.amazon.com/Cyclone-Colle...55&s=hi&sr=1-4
I have a Harbor freight variable speed controller for the shop vac.
I added LED light.
As soon as I started using it my shop vac it stopped working. I took it apart and the switch was fine then I looked at the thermal overload was good to my surprise.
I found the issue. You can see here the wire for one of the windings was broken. I will fix this after work.
I am using a bucket Vac but the 5-gallon shop vac worked so much better.
Here is a tractor step I sandblasted and powder coated. It is shipping to a customer today.
The only thing I need to seal up is the door.
I need to add some flashing to the door bottom.
I don’t want it to get a direct spray.
ID:	8878   Click image for larger version
ID:	8879   Click image for larger version
ID:	8880   Click image for larger version
ID:	8881   Click image for larger version
ID:	8883   Click image for larger version
Daox (03-23-20), WoodBurner (03-23-20)
Old 03-23-20, 01:16 PM   #2
WoodBurner
Wow, that is a sturdy looking step, thanks for the write up!
g
WoodBurner is offline   Reply With Quote
Old 03-23-20, 01:25 PM   #3
It is ¼” thick steel plate. We tested it out with over 400 pounds and it did fine.
Old 03-23-20, 02:59 PM   #4
Nice mods! I tried one of the table top versions years ago. It was pretty horrible. I modified and it still didn't work well. The tray on the bottom wasn't steep enough to return the sand to the pickup tube.
Old 03-23-20, 03:23 PM   #5
Thanks.
I had one step that I did not get good powder coat coverage. I was able to sand blast it off pretty easily.
You only have to use about two or three cups of media
My shop vac is back and running the winding that was broken was never soldered at the factory. It is strange the other side was soldered.
It needed a good cleaning.
Old 04-28-20, 08:01 AM   #6
I like my mods to the sand blast cabinet but the siphon feed is to slow for what I need.
I bought a HF Pressurized Abrasive Blaster. They have two models buy the 60696 it holds 2 more liter more and have vent holes to allow air to exit while filling and pressurize the gasket to seal better. I am using this inside my cabinet. The cabinet captures the media and I refill the pressure tank with the captured media.
https://www.ameriblaster.com/shop
ameriblaster sells upgrades for this pressure pot. To make go form decent to great.
The ameriblaster parts come in later this week.
The speed to clean a part has been reduced greatly. I added a vibration motor and slowing it down with a HF router control. This really helps keep the media flowing. ameriblaster says with their kit you do not need the vibration motor but their kit was out of stock because of the Coronavirus. The vibration motor make HF version work until I get the kit in.
I got the valve relocation kit. That makes it so I don't have get on the floor every time I need to adjust the flow. I am getting to old for that.
It will look similar to this.
I am using coal slag from tractor supply 9.99 50 pound bag.
I am selling more steps so I need faster blasting. I have to sandblast before powder coating.
These shipped yesterday.
ID:	8941   Click image for larger version
ID:	8942   Click image for larger version
ID:	8943   Click image for larger version
ID:	8944   Click image for larger version
WoodBurner (04-28-20)
Old 04-28-20, 11:23 AM   #7
WoodBurner
Wow, sold 15! Also thank for the details on how I can set up a sand blaster, I had no idea about using coal slag.
G
Old 04-28-20, 11:51 AM   #8
This shows what HF pressure pot comes with the dead man valve and what Ameriblaster kit does for it.
The on and off valve for mine will be outside the cabinet. The speed difference between pressure pot and siphon feed is like night and day.
Old 05-02-20, 10:27 PM   #9
I have the sand blasting working very well at this point. I will upgrade a couple a couple valves and make a bracket to hold the relocated manifold.
No more getting on the floor to adjust the pressure pot. The pressure pot now works without messing with it.
I cut some ¼” plate to mount the air input I put the one valve inside the cabinet.
I moved my old foot valve to my air assisted 20 ton brake press.
ID:	8949   Click image for larger version
Daox (05-03-20)
Old 05-05-20, 03:46 PM   #10
I don’t have a good way to do a video of the difference between suction or pressure blasting.
This video uses the same media to show the difference.
Do both methods work yes but pressure sure speeds it up.
