Old 09-13-18, 11:55 AM   #1
Default New Gree Sapphire? -22F
https://comfortup.com/products/gree-...s-12k-sapphire
I just saw the Sapphire units. -22F is the type of MS I'm looking for,
to replace the old Sanyo in the den..
Anyone seen any user info on this 'new' line?
Old 09-13-18, 01:05 PM   #2
http://17uo7e27w1attiybs22of10v.wpen...081318_Web.pdf
This link has all the info on this model.
http://www.greecomfort.com/resources...ump_Revision_A
That looks sweet. That is above their CROWN line it has a 2 stage compressor. The crown is two stage compressor also.
That is two places above my TERRA SERIES.
The crown is on the right.
The crown puts out a little more heat but it uses more power to do it.
I bet that would work great in your climate.
They have it a little cheaper here.
https://www.coolrunninghs.com/sap12hp230v1a.html
Maybe you could find a coupon code to add on top of it. (I have never bought form this company)
Xringer (09-13-18)
Old 09-13-18, 08:28 PM   #3
After comparing the size, weight and power use of the 9k and 12k units,
I wonder if the difference is a firmware limit on motor speeds.?.
For $100 more, I'll take the 12k unit..
Old 09-14-18, 11:25 AM   #4
Jeff said before that a lot of times it is exactly what you said the exact same units just different firmware.
Between the 9K ant 12K units.
They just run the 12K unit a litter harder and it uses just a little more power.
( I am ruffly quoting Jeff here this is now my core knowledge )
