Old 05-30-16, 02:24 PM   #1
Zwerius
Zwerius's Avatar
Default Hydronic floor heating only 15 mm height
Hi there,
Wanted to show you, how I added floor heating to our bedrooms (first floor).
First installed preformed insulation plates, with grooves for fitting aluminum heat dividers,
[IMG][/IMG]
secondly installed the aluminum heat divider plates,
[IMG][/IMG]
thirdly installed the pipes
[IMG][/IMG]
and finally the laminate:
[IMG][/IMG]
For more details, take a look at my website (in Dutch): Toch vloerverwarming - geen energierekening meer:energie+ woonhuis van de fam. Kriegsman in Ootmarsum
The Following User Says Thank You to Zwerius For This Useful Post:
Daox (05-31-16)
Old 05-31-16, 09:43 AM   #2
Wow, 15mm is really thin! That is just under 5/8" for us non metric users.
What is the distance between the tubes?
Old 05-31-16, 10:04 AM   #3
Zwerius
Zwerius's Avatar
The distance between the tubes is 10 cm (4"). The tubes are 10 mm O.D.
Old 11-02-17, 05:02 AM   #4
Zwerius
Zwerius's Avatar
Yes, that's thin. But it is functioning very well.
I'm having a max. watertemperature (supply to the floor) of 32°C (89.6 F) in winter. The heating is calculated for an outside temperature of -12°C (=10.4 F).
With those temperatures we can achieve an indoor temperature of 22°C (71.6 F).
