Old 09-18-14, 10:54 AM   #1
Default Clearance LEDs near you
Lows has a bunch of LEDs on clearance.
Some of the larger out door "90w replacement" flood LEDs are as much as $10 off the original price.
They have everything from low voltage track light LEDs, to LEDs that you could put in a table lamp, out side porch light or indoor light fixture all the way to 10w LED floods.
I want to replace all my current out door halogens with LEDs and expand what I have. Problem is the flood LED is the most expensive part.
This will lessen the pain.
I guess whats on clearance will depend on whats left in your store, if you live in a more hippy type area where every one is already buying LEDs the selection might not be so great.
Wher I live power is cheap, so they haven't been big sellers.
Power here might be cheap, but ultimatly I am cheaper so I replace 100w floods with 10w LEDs and replace 300-500 watt halogens with $10 dual flood lamp fixtures armed with twin 10w LEDs.
Swaping a 300 to 500 watt fixture for a 20watt fixture, yeah I can see that paying for its self at some point.
I work out side on projects well into the night.
Daox (11-11-14)
Old 09-18-14, 11:21 AM   #2
Thanks for the heads up I still need a couple LED flood lights.
Old 09-19-14, 07:50 AM   #3
gtojohn
gtojohn's Avatar
Great, I'll be checking my lowes. I already replaced 6 of my outdoor cfl lights a few months ago. Kept a bright cfl on a switch by the bbq pit. I figure my timered outdoor lights run longer each day than any other lights in my house, so pay back should be sooner.
Old 09-19-14, 09:52 AM   #4
Although not exactly about clearance LEDs...
I just picked up a quantity of eight 60 watt equivalent bulbs at Ikea for $4.65 each.
Old 09-19-14, 11:48 AM   #5
Really cold temperatures kill CFLs, so might be time to switch your out side CFLs for LEDs.
AC_Hacker (09-19-14)
Old 09-28-14, 11:29 PM   #6
Lowes is still getting shipments of these clearance LEDs in.
I went there to buy some yesterday and it looked like there were a lot more on the shelf.
Maybe they will get marked down again.
Old 09-29-14, 09:03 PM   #7
Servicetech
Servicetech's Avatar
Home depot had some PAR38 1300Lumen LED's for $10.
Old 10-14-14, 05:22 AM   #8
sidhqmmty
That's great work. I'll check it.
sidhqmmty is offline   Reply With Quote
Old 06-21-15, 07:09 AM   #9
Boz86
Lowes has "regular" medium base 9.5w (60w equiv) on sale for $2.48 now.
Not quite the deal I got on CFLs at $.33 each a decade ago on some sort of special sale, but then again I'm almost finished with my CFL stash.
Boz86 is offline   Reply With Quote
The Following User Says Thank You to Boz86 For This Useful Post:
Servicetech (06-21-15)
Old 06-21-15, 08:02 AM   #10
Servicetech
Home Depot had some Phillips 800 lumen 2 pack for $5.
