Old 01-08-12, 07:48 PM   #1
Default Does bubble-wrap work for insulating windows?
For $15, I bought a roll of 24" wide roll of bubble wrap, enough for three or four windows (I only wanted to do the lower windows).
On a single glass window with no storm window, it makes a big difference!
I also tried it on single-glass with storm and next on Argon-filled double low-E windows, on each one , the difference was less than the previous test. The difference on double-glass, Argon-filled double low-E window was almost too low to read.
Take-away:
  • If you have single-glass windows, bubble-wrap can certainly help. At $15 for several windows, it is tremendous bang for the buck.
  • If you have single-glass with storms it will help a little.
  • If you spent $300 on Argon filled double low-E, don't bother to invest $15 to cover your Argon-filled windows with bubble wrap.
The Following 7 Users Say Thank You to AC_Hacker For This Useful Post:
Daox (01-09-12), Exeric (01-17-13), philb (01-09-12), Quest (01-09-12), razor02097 (12-03-13), S-F (01-10-12), TimJFowler (01-11-12)
Old 01-08-12, 08:40 PM   #2
iamgeo
From everything I have read it works very well.
I would suggest asking friends and/or going to most any store and getting the wrap for free.
To clarify that last line.
Ask for the wrap they received in packages sent to them.
Old 01-09-12, 07:21 PM   #3
GaryGary
Hi AC,
I had a go at measuring the performance of bubble wrap on our double glazed low e windows back in 2005:
BubbleWrapPerformance
The results looked pretty good -- better than I would have expected by just saying the the bubble wrap adds about R1 to what is already there. Not sure if this is a flaw in the technique I used, or just that the bubble wrap did a bit better than expected.
Based on the double glazed low-e having an R value of about 3 (U of 0.33) and the bubble wrap adding R1, you would expect about a 25% drop in heat loss by adding the bubble wrap.
But, the measurements I took came out at about a 45% reduction in heat loss.
Anyone have a better way of measuring the actual performance?
I now have an IR thermal camera, which would make getting overall window temps easier.
It would be nice to know what the real number is.
Gary
Old 01-09-12, 10:00 PM   #4
I could have saved myself so much trouble and expense if I hadn't put in 3 layers of 2 inch XPS in the walls (R-30 for 6"), carefully sealed at every layer.
Instead, I should have wrapped my kitchen in bubble wrap.
What a fool I was!
ctgottapee (12-19-13), keithstef (01-26-12)
Old 01-10-12, 03:29 PM   #5
GaryGary
I think you should have just run the 6 inch R30 right over the windows
Gary
Old 01-10-12, 03:37 PM   #6
Gary
The view was not so magnificent, anyway!
Old 01-11-12, 10:04 AM   #7
Gary
*Puts flame suit on* I'm actually considering this, removing the wood blinds(which are dark and pull a ton of heat in) and attaching some drapery to the insulation, gasketing the edge and shoving a 2" sheet of XPS against the glass on the inside. Granted it isn't the outside but its also going to be on the front of the house so I'd like it to look somewhat normal. I'm thinking blocking the light will do more than the R10 will but it should amount to a roughly R12 window assembly that kicks the crap out of the performance of low-E gas. Would this work as well as I think it would?
Old 01-12-12, 09:46 PM   #8
GaryGary
I've been putting rigid foam board in some of our windows. I use the Atlas R-Board insulation in that it has nice light grey face sheets on the foam board that look nice and take paint well.
This is one of my windows:
A High R-Value Window Insulation Shutter with Good Light
I've since added it to several other windows that we don't look out of much. I've only been covering about 3/4's of the windows, leaving a gap at the top to let daylight in.
One inch of the R-BOARD is R6.5 -- its polyiso, so has high R per inch.
You could use 1.5 or 2 inch and get as much as R13 just from the foam board.
Also used the same stuff on our sliding glass door:
Insulating a Sliding Glass Door
I was going to take this out during the summer, but we just decided to leave it in year round as it does not interfere with the use of the door and still lets in plenty of light.
Gary
Old 01-14-12, 05:10 PM   #9
I've been putting rigid foam board in some of our windows...
I came across a similar scheme before that employed a combination of thin 'stick-on' magnet stuff around the window (or door) frame, and thin sheet metal around the insulating board edge.
This made for easy removal/detachment and also good seal.
Old 01-17-13, 04:20 PM   #10
liuite
Too bad we can't test this idea with Argon filled bubble wrap
liuite is offline   Reply With Quote
