Old 11-25-09, 12:14 PM   #1
cdig
Default Mount electric furnace upside down?
I've finally gotten my garage insulated and purchased an old electric furnace to heat it with. I'd like to mount it in the corner up near the roof because a) floor space is at a premium, and b) I'm cheap and want it as close to my fuse panel as possible to save on wiring expense.
The problem is that this unit is a top feed, so the hot air comes out the top. I'm wondering if anyone knows if I can mount it upside down? One forum post I read somewhere said that it would eventually melt the wiring in it... which seems plausible so I'll check that. Any other 'gotchas' I might need to look into before trying this?
cdig is offline   Reply With Quote
Old 11-25-09, 03:41 PM   #2
The hot air comes out of the top because heat goes up, if you want it to come out of the bottom you are going to need a stronger fan and are going to need to seal the whole unit better so you can push that hot air down, you are also going to need to make sure that the thermostat is placed in such a way as it stays on long enough to get the heat out of the unit, it's also going to now be placed in such a way as it will not get hot in the first place... risk of starting your garage on fire greatly increase if you do any of this wrong.
Old 11-25-09, 08:01 PM   #3
Use a window A/C installed backwards as a heat pump.
Old 11-28-09, 02:05 PM   #4
dremd
Need More Eco
dremd's Avatar
How about a few feet of duct?
