Old 10-31-20, 09:46 AM   #1
dguzzi
Default Water heater element for smoker
Do you suppose a water heater element would get hot enough to use as a starter for wood chips or pellets? I'd like to use it for a cold smoker.
I wonder if they get red hot in open air?
dguzzi is offline   Reply With Quote
Old 11-01-20, 01:16 AM   #2
If you put full power to one it will over heat and fail. Maybe if you put 120v on a 240V it wouldn't.
I think you best bet would be to use an "electric grill" or a hot water heater element on a varrac.
Old 11-01-20, 07:16 AM   #3
dguzzi
Yes i'll have to control it, probably only on long enough for good heat. Also overtemp protection.
Old 11-01-20, 07:18 AM   #4
Stovetop heating elements would probably be a better choice.
Old 11-01-20, 07:20 AM   #5
dguzzi
Maybe, but size is a factor.
Old 11-01-20, 02:31 PM   #6
I was thinking start with something like this.
Old 11-01-20, 05:03 PM   #7
dguzzi
I'm goin homemade on this, that is overkill for my needs at this time!
Old 11-02-20, 07:22 AM   #8
Umm how about a hot surface igniter? They're used in gss furnaces everywhere.
Old 11-02-20, 09:45 AM   #9
dguzzi
I think maybe that's to fragile, I would be able to clean a bigger element easier. Not a bad idea though. Water heater element is less than 15$, thats what made me think of it.
Old 11-02-20, 10:17 AM   #10
I'm guessing you could find an electric charcoal starter locally for around 9.95. Most are not tiny, use about 500 watts, and last a long, long time. I believe the one collecting dust in the garage is at least 30 years old. Think sporting goods or farm stores with a decent camping department.
Another idea is an element from a toaster oven.
