Old 01-25-20, 08:45 PM   #1
Default Help identifying electrical connector
Hey guys, I am looking to identify this electrical connector, but for the life of me I can't find what it is. I want to replace it. I searched through digikey a bit, but there are a few connectors in their catalog haha. Suffice to say, I didn't find it. Any help would be appreciated!
Old 01-25-20, 11:29 PM   #2
I suggest asking EEVblog. It looks like a JST SH but it's important to examine the connector carefully since I have seen variants with subtle differences specifically to prevent cross connections.
The Following 2 Users Say Thank You to NiHaoMike For This Useful Post:
Daox (01-26-20), jeff5may (02-08-20)
Old 01-26-20, 10:35 PM   #3
where2
DIY Geek
For others who may someday need this knowledge:
Using NiHaoMike's suggestion as a starting point, I was able to determine that JST connectors come in a variety of pin spacings: 1.0mm, 1.25mm, 1.5mm, 2.0mm, etc. Knowing the pin spacing helps in determining the specific connector.
If Daox has an SH connector as Mike suggests, the measurements of the plug should be 2.5mm (wide, on the plane of the female pins), the rear portion of the connector is likely 3mm high, and the length of the connector is likely 5mm (along the direction of male pin insertion, from the tip of the connector to the back where the wires exit).
I got those measurements from an image posted by an amazon seller called Hobbymart who was selling lots of 20 of those connectors with wire tails. They also had other listings for a variety of JST connectors using 1mm pin spacing with images and dimensions for the connectors.
I appreciate NiHaoMike's reply, as I was recently searching for information about a connector used on an inexpensive RC Drone battery. These JST connectors are all over modern modular electronic devices and radio controlled devices.
jeff5may (02-08-20)
Old 02-03-20, 01:39 PM   #4
I just wanted to follow up with a big thanks to Mike! I ordered the JST SH connector and it fits perfectly. Thanks so much!
