Old 10-18-19, 05:34 PM   #1
CrankyDoug
Default Acrylic vs polycarbonate (Lexan) for storm windows
I have to make four removable storm windows for the skylight in my house. They are trapezoidal so there will be a lot of waste. I will need two 4X8 sheets.
Acrylic is less expensive than polycarbonate. I'm not concerned about impact damage. The question is which will hold up better under heavy sunlight and semi-regular cleaning.
Acrylic can be polished if it gets scratched. I've never had any luck removing scratches from polycarbonate but then maybe I didn't know what I was doing.
Any recommendations?
Old 10-18-19, 09:20 PM   #2
jjackstone
Acrylic tends to shatter into shards if it breaks. Polycarbonate not so much. Lexan likely has better UV resistance also so should last longer in the sun.
JJ
Old 10-23-19, 12:27 AM   #3
johny5
Sheet grade polycarbonate and acrylic sheet are two of the most frequently used see-through plastics. Acrylic is shinier and polycarb is stronger. Acrylic is less expensive but easier to crack. Polycarb is more impact resistant but easier to scratch.
johny5 is offline   Reply With Quote
Old 11-20-19, 11:28 AM   #4
orange
frugal builder
Acrylic. Acrylic Acrylic. Polycarb yellows in the sun and is much easier to scratch. When I built my first house, I used acrylic.
We are used to double pane glass which has a lot of reflections. When clean, the acrylic windows were so beautiful because they looked like there was nothing there. The garden looked like it was an extension of the house.
orange is offline   Reply With Quote
