Old 02-09-18, 09:12 AM   #1
bennelson
Home-Wrecker
Default Passive Solar Garage Door
Hi Folks!
I recently built a Passive Solar Garage Door!
Not a new or original idea, but still a good one. I loosely based mine on the one Gary Reysa wrote about in Home Power #117 (Link HERE)
My garage has two 9'x7' insulated garage doors. They are steel on both sides and filled with urethane foam - about the best R-value you can get before going to some sort of a custom modified door.
I built a "Storm Door" for the right-hand side door out of wood and plexiglass. It is split in half and hinged so that it opens to the outside.
It's dual pane, by using the plexiglass and then adding a plastic window insulator kit to the inside.
On a sunny day, I just open the garage door to let in the heat and light. At night and cloudy/snowy days, the garage door is left down to keep the heat inside.
Full write-up on the project is posted on Instructables.
https://www.instructables.com/id/Pas...r-Garage-Door/
Temperature inside the garage can be 20+ degrees warmer inside than ambient temperature.
I could still add glazing to the other garage door, but I'm still using that side for parking a car. I wouldn't want to add additional glazing unless I can figure out a good way to still make it convenient to move a car in and out.
ID:	8147   Click image for larger version
ID:	8148   Click image for larger version
ID:	8149   Click image for larger version
ID:	8150   Click image for larger version
The Following 6 Users Say Thank You to bennelson For This Useful Post:
ctgottapee (03-09-18), GaryGary (03-09-18), MetroMPG (03-08-18), stevehull (02-09-18), sunspot (02-10-18), where2 (02-11-18)
Old 02-12-18, 09:13 AM   #2
Very nice Ben! That looks like a great solution. And it looks like you did a really nice job. How much did the materials cost for it out of curiosity?
Old 02-12-18, 09:19 PM   #3
bennelson
Home-Wrecker
Materials cost was a bit high.
Plexiglass was $120 a sheet (and I needed two 4'x8' sheets)
Lumber was on the pricey side too, but I was using NICE lumber which is pre-primed. That pre-primed is kind of a life-saver as it's winter, and it's kinda hard to do a good exterior paint job in the cold outdoors! I simply assembled the project, and it looked very finished because of the priming.
I'll add a coat of real paint once the weather is a little nicer.
Twin wall polycarbonate is less expensive, but also slightly less transparent, and I like the nice view through the window.
In total, my cost was about $500. The project certainly can be done cheaper than that, but I am pleased with the overall results.
The Following 2 Users Say Thank You to bennelson For This Useful Post:
Daox (02-14-18), Roostre (02-14-18)
Old 03-09-18, 11:17 AM   #4
GaryGary
Hi,
Looks great!
Mine is more than 10 years old now and still going strong.
Only change I've made was to change the lower glazing panels from Acrylic to twinwall polycarbonate after banging into with with the car
Aside from the nice solar heat its great to work in a shop/garage with good solar lighting.
Gary
glazing, passive, solar, thermal, window
