Old 09-04-09, 08:33 AM   #1
Default preventing infiltration/convection - old semi used chimney
I have a chimney in my house. However, it was chopped off when the roof was redone shortly before I bought the house. This provides a great way to loose heat through the winter as it runs the length of the two stories and is not capped off in the attic. My problem is that the water heater vent pipe is run up the chimney. I'm sure it gets warm (not sure how warm) when the heater is running. How can I seal/cap the chimney in the attic to stop it from channeling all my heat out of the house? Almost all insulation isn't made to be used next to something that gets hot.
Old 09-04-09, 12:23 PM   #2
A little more searching on my part found this energy star document on sealing your house. It is quite informative and has nice pictures too.
The pictures below really aren't hard to follow. Looks like I need to get some high temp silicon caulk.
ID:	319   Click image for larger version
ID:	320   Click image for larger version
chimney, insulate, seal
