Old 08-24-09, 09:35 AM   #1
Applewood
Default River power
I have looked for info on generating electricity from large slow moving bodies of water and have found very little. I would like to place a generator on a floating dock where the currant is about 1 or 2 miles per hour. Can any one help or direct me to where I can get ideas and info?
Roger
Applewood is offline   Reply With Quote
Old 08-24-09, 09:58 AM   #2
First off, welcome to the site! Its cool to see someone here interested in hydro power.
Would you be able to pipe off the river and go downhill to a generator station? The greater the head of water you can get the more power you'll get out of the system. I posted something like this a while back.
http://ecorenovator.org/forum/other-...ric-setup.html
We did have a post on a book about a water wheel farm setup here.
http://ecorenovator.org/forum/other-...ty-1915-a.html
Builditsolar.com is also another vast resource of info that I would check out.
Small Scale Hydro -- Ram Pumps and Water Motors
Old 08-24-09, 11:04 AM   #3
Applewood
Default River power
There is no option to raise the head of the river water. I will look into the 'farm electricity' as suggested soon. BuildItSolar is one of my favorite sites but has little that applies to my situation.
I live beside a navigable river that flows thru flat countryside here. I'm thinking that a floating platform with an undershot waterwheel could harness some of the unstoppable mass of water that passes by. It seems that a broad 6' to 8' wide wheel with similar diameter dipping about 2' into the flow would give plenty of torque. Gearing could be stepped as needed to match the generator.
I would like to do the math before the building so help with that is needed. Just references to sources or formulas would be fine.
Thanks
Roger
Old 08-24-09, 03:54 PM   #4
This is the best thing I could find.
Calculation of Hydro Power - Hydro
I plugged some numbers in for fun to see what comes out. I used .1 meters of head. I then used 680 liters of flow per second (base off really rough calculations that I'm unsure of and I assumed 2 mph water). This gave 667W of hydro power and 400W @ 60% efficiency.
Old 08-27-09, 09:28 PM   #5
Christ
Gonna have to check that link out , and see if I can find the downloadable calculator I found yesterday, but my download failed. If I find it, I'll post it here.
