05-17-17, 09:37 AM | #1 |
Friend of Entropy
Mounting PV panel supports
Last year I tore down my old crappy garage and am in the midst of rebuilding it. The new design is optimized for solar exposure so I can install PV eventually but can't afford it right away (this new building stuff is expensive!).
As I'm installing the new roof I am planning on installing the mounts for the future PV system. Question: is there a "standard" spacing for these mounts to accept the rack system (or different types of rack systems) and ultimately the panels themselves? Thanks for any info.... |
05-17-17, 09:54 AM | #2 |
Here is a great tool to decide what you need.
http://design.unirac.com/tool/projec.../?pitched=true It is based on more than one thing. Snow load, wind speed expected…..
The Following User Says Thank You to pinballlooking For This Useful Post: | mk1st (05-17-17) |
07-17-17, 11:21 AM | #3 |
Friend of Entropy
Update: here's the progress: Ordered Quick Mount PV kits (very nice), all set for the future panel installation!
https://www.dropbox.com/s/yq4oj3srik..._1433.JPG?dl=0 |
07-17-17, 07:40 PM | #4 |
DIY Geek
That's it, I need to do this to my gambrel barn in Maine...
Tags |
mounting, rack, roof, rooftop solar panels |
