Old 08-21-15, 10:32 PM   #1
Default FLIR i7
New favorite toy.
One is not like all the others.
I put the amp clamp on it. It only had 10 amps, powering 2 window AC units. 2 bedrooms on one circuit. That's 1960s wiring for you. The breaker box is a modern QO 200amp load center I installed.
Dog.
Self explanatory.
Here is the difference between more insulation and less.
One void between the walls is not filled with cellulose. Can you guess which one?
Satellite DVR.
Soaking up the power.
Gas water heater pictures.
I am likely going to replace this one with an electric since it only provides water to the back bathroom only.
ID:	5757   Click image for larger version
ID:	5758   Click image for larger version
ID:	5759   Click image for larger version
ID:	5760   Click image for larger version
ID:	5762   Click image for larger version
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Daox (09-02-15), Piwoslaw (09-27-15)
Old 08-22-15, 07:26 AM   #2
Nice pictures. I can't wait until they ship my Flir one.
Old 08-30-15, 12:30 PM   #3
Here is a before and after picture of a wall light with a 40 watt bulb, then replaced with a 7 watt, 60 watt equivalent LED.
Both pictures the light had been left on all morning.
ID:	5784   Click image for larger version
Daox (09-02-15)
Old 08-31-15, 05:37 PM   #4
Default Main Source of Heat Loss...
oil pan 4,
I think I found the major source of your heat loss.
It is this strangely shaped object in the photo below:
If this is an appliance, it certainly is a strange looking appliance. It would be a good idea to see if there are any other models of this appliance that are "Energy Star" rated.
If you look at any of your other images, none of them come even close to this one in terms of wasted heat.
In fact, along the bottom edge of the photo you can see what a huge amoint is lost from the appliance plug-in cord alone.
All in all, I can't imagine any way to utilize an appliance as wasteful as this one is.
Good you got your Flir 7... otherwise, you never would have known.
Sincerely,
Piwoslaw (09-27-15)
Old 09-02-15, 09:33 AM   #5
gtojohn
gtojohn's Avatar
I took 2 of those heaters camping in February. We were forecast for a light freeze in the morning. The smaller heater got cold enough it crawled inside my mummy bag. The bigger one was fine on top of my daughters bag. We were toasty warm, even had to unzip some. My friends in the neighboring tent told me they were so cold they couldn't sleep. Good little heaters but a lot of upkeep!
Old 09-02-15, 09:06 PM   #6
My dog was real hot that day I just let him in.
The dogs keep crack heads, thieves and other liars out of my back yard.
Here is my echo 440 saw a few minutes after cutting up some standing dead trees. Cutting kiln dried hard wood logs really heats up the bar and chain.
The oiler is turned up on the max setting and I grease the bearing on the end of the bar.
I was mostly doing cold cuts where you cut with the top of the bar, that uses all for cooling and lubing bar and chain. As opposed to a normal cut on the bottom of the bar where some of the oil flings off when the chain makes that turn round the end of the bar.
ID:	5810   Click image for larger version
Old 09-03-15, 10:59 PM   #7
Quest
oil pan 4,
Sincerely,
LOL! I too, had one of these flea-bitten high heat loss device in the house. Good to have it with me while camping (keeping the tent+ sleeping bag warm, but fleas kept me awake anyways)....mine tend to be somewhat high maintenance and low thermal efficiency (still considered high heat loss).
If only I can find a hypoallergenic type with lower maintenance cost (less medical costs overall) and energystar 2.0 certified (I believe standby power consumption shouldn't exceed 0.4~0.6watts/hr), that would be ideal...but then again: that rather "cold-blooded" heater may not serve me all that well during camping trips....need longer time to warm up the sleeping bag...
Decisions, decisions, oh well, too late to get one nowadays...I've made up my mind to severe the ties with these high heatloss device altogether, but to rely on artificial forms of heating the house....
Good try though..
Old 09-04-15, 12:21 AM   #8
Haven't owned one but Sony used to make a version with built in Wifi.
https://en.wikipedia.org/wiki/AIBO
Pretty sure it would easily fit your "low power" needs but the biggest problem (apart from trying to get one) is that I don't think it supports WPA2, meaning your network would be less secure.
Maybe it's time to develop an open hardware version. With a big focus on DIY serviceability, which is much to be said when most devices of that type are substantially less DIY service friendly than the latest iPhone...
Old 09-04-15, 11:21 PM   #9
Gasoline lawn mower.
ID:	5819   Click image for larger version
Old 09-05-15, 06:53 PM   #10
Elcam84
Nice shots. One of those or similar is pretty high on my list of toys I want.
diesel engine, efficiency, flir, insulation, lawn mower
