Old 03-26-15, 08:49 AM   #1
Default EKM 120/240V kWh meters
I was reading on an i-miev (Mitsubishi electric car) forum about these devices. While not cheap compared to the kill a watt, they at least are an option.
EKM - Electric Meters (KWh Meters)
Old 03-28-15, 09:10 AM   #2
gtojohn
gtojohn's Avatar
I just picked up the Efergy Elite kw meter for a song. It uses clamps over your service wires inside your breaker panel. It gives a nice real time reading. It immediately drove me nuts to see the power im consuming at idle! And od course even worse when the appliances are running.
Old 03-29-15, 07:05 AM   #3
Where did you get it (Efergy Elite Meter) and how much?
Old 03-29-15, 10:56 PM   #4
gtojohn
gtojohn's Avatar
They're out there on Amazon $113 and ebay for less. Mine was an open box special for $35. They come standard with only one sensor, which works for folks with balanced 220v. The sensor for my other leg was $20 more. The same unit has inputs for up to 3 sensors and 3 phase power.
Daox (03-30-15)
