Old 03-08-15, 09:24 AM   #1
mechanic
Default 78mm halogen
Anybody find a good led replacement for these little gremlins? All my bathrooms have five of these above the mirrors and they are the only lights I haven't addressed yet, pulled one out today and they are 100w each!!! I could leave all 67 outdoor and indoor lights on and they would use less than leaving the lights on in two bathrooms....
mechanic is offline   Reply With Quote
Old 03-08-15, 09:29 AM   #2
mechanic
I found these but there's no room in my fixture...
T3 LED 5 Watt 85-265VAC Double Ended R7S 78mm 3-1/8-Inch - Household LED Lights - LEDLight
Old 03-08-15, 12:01 PM   #3
I hate those things. I had them in some 500w work lights and they always burn out. And yes, they suck power.
You may have to change the fixture.
Servicetech (04-08-15)
Old 03-14-15, 04:13 AM   #4
Ator
I had the same problem and bought these: 2015 newest 78mm LED R7S light 6w 360 degree beam angle J118 R7S lamp replace halogen lamp 118mm 135mm 189mmAC85 265V-in LED Bulbs & Tubes from Lights & Lighting on Aliexpress.com | Alibaba Group
It's not the prettiest solution, but does work wonders. If you have enough time for these projects I would consider replacing the fixtures.
Ator is offline   Reply With Quote
Old 04-07-15, 10:56 AM   #5
WyrTwister
In the winter , they are a source of heat .
What other source of heat do you have in the bathrooms ?
God bless
Wyr
Old 04-07-15, 11:21 AM   #6
mechanic
Ground to air heat pump, ducted throughout the home
Old 04-07-15, 11:29 AM   #7
WyrTwister
So , you do not " need " the 500 watts of electric heat , unless the bathroom is on the north side of the house ?
You could just install one or more ceiling lights with LED lamps and put them on another switch .
Turn on the quartz lamps only when you need supplemental light ( or heat ) .
At one time a lot of bathrooms used 250 watt heat lamps .
God bless
Wyr
Old 04-07-15, 07:53 PM   #8
mechanic
Oh ya I don't need the heat, wife likes the lights above the mirror for getting ready and what not though
Old 04-08-15, 05:58 AM   #9
Servicetech
Servicetech's Avatar
Just buy a LED light bar and put it above the mirror.
Old 09-02-15, 07:24 AM   #10
mechanic
Ground source heat pump, temperature stays nice and even throughout the home
