Old 01-15-15, 08:24 AM   #1
Default T5 13W florescent ballast
Its been a while, but I had an under cabinet light go out. I've figured out it was the ballast that went bad on it. I pulled it apart and saw that a resistor was toasted on the board. I pulled apart another one to see what the resistor value was and soldered a new one in. It didn't work. So, I'm looking for a replacement ballast. These apparently aren't available locally for me, and I haven't had good luck on Amazon either. I tried a T12 ballast, but the bulb runs quite a bit warmer than the one next to it.
Does anyone have a source for ballasts they can recommend?
Old 01-15-15, 10:24 AM   #2
Might be a good time to upgrade the light to LED , if they sell LED tubes in that length ..?
If needed the LED ballasts are cheap on eBay $5-$10 then you could reuse the fixture.
Old 04-19-15, 08:31 AM   #3
WyrTwister
Go to an electrical supply house . Or try a google search .
God bless
Wyr
Old 04-20-15, 12:13 PM   #4
I ended up doing a bit more digging on amazon and found what I needed.
