Old 01-21-14, 08:21 PM   #1
Default 12,000btu fuji
Right then....12000btu Fujitsu ductless in my shop. Popped in while the temps were -18C outside and checked the current on the unit....6.5A on each leg.
Anyone got a 1 ton to compare against? Might not be a fair comparison as I lost a bit of oil and doubtless a bit of gas as well over the recent cold spell.
Old 01-22-14, 08:34 AM   #2
WyrTwister
Is yours 240 VAC ( single phase ) ?
I installed a 13 SEER 12,000 mini split A/C - Heat Pump , this summer . It is 120 VAC . Pulls about 10 amps , this last summer . Have not checked the amperage this winter ?
Does your Fujitsu heet well at -18C ? My HP starts to strain and take a long time to cycle off beginning around 25F .
God bless
Wyr
Old 01-22-14, 08:46 AM   #3
The Fuji is a 24 seer unit, IIRC 10.2 HSPF. 240Vac
It is not straining to heat but it doesn't seem to be shutting off so i couldn't tell you if it is near its limit. I don't have a basic air thermometer in the shop but I should get one.
Old 01-22-14, 09:51 AM   #4
WyrTwister
My 13 SEER unit cycles , like a traditional A/C unit . My understanding is the high SEER units use a different technology .
The outside unit has sophisticated electronics to monitor the temps and pressures and the ability to modulate the power . The compressor is made to run at variable speed , paired up with the electronics .
The net results is , in stead of cycling the system off and on , the compressor changes speed with changing load .
So , your system may be slowing down , in stead of cycling ?
If your system is pulling 6.5 amps of 240 VAC , that comes down to a little greater wattage than my unit with 10 amps at 120 VAC , for cool ?
Not what I would guess for your high SEER unit ?
God bless
Wyr
Old 01-22-14, 09:56 AM   #5
Unfortunately it isn't a good comparison because the conditions are totally different. Maybe Xringer could chime in too or anyone else as well.
Old 01-22-14, 10:07 AM   #6
WyrTwister
Using his data 6.5 amps x 240 VAC = 1560 watts .
My data 10 amps x 120 VAC = 1200 watts .
Admittedly , my data was summer time cooling , his winter heating .
But amps is amps , volts is volts and watts is watts .
I noticed he was quoting temperature in Centigrade / Celsius . I quoted temperature in Fahrenheit . So , he may be on the other side of the pond ? Or may be our northern neighbor ?
But no matter where we happen to be located on the globe , Newtonian physics seems to work pretty much the same .
God bless
Wyr
Old 01-22-14, 01:30 PM   #7
randen
Uber EcoRenovator
Default Fujitsu rival
A homemade GSHP running on BBQ propane 2.5 T, and your familiar with it.
7.3 Amp @ 230 Volt 1 ph.
Just for comparison.
The O/S air temp -24 Deg C. Shop temp dips to 12 Deg. C Recovers to 16 Deg. by lunch time. Could use a little larger unit!!!
Randen
Old 01-23-14, 06:50 AM   #8
The issue is the the spread between indoor condensing temp (pressure) the evap temp (which in my case is -20C). Randen has a GSHP so the temp difference will naturally be narrower at -20C outdoor and current will be lower for the same pot.
Even the AHRI couldn't figure out how to measure efficiency with inverter systems, for the longest time. I guess that means that my value of 6.5A/leg is kind of irrelevant as it is just a snapshot in time.
Old 01-23-14, 08:00 AM   #9
WyrTwister
What do your specs say as far as max run amps ?
You are correct , an an inverter system , the 6.5 amps may be though of as a snap shot of what it is doing as that specific time .
Did you measure the amperage going in ? The amperage going to the compressor would be difficult to calculate into watts . And it would not include the energy consumption of the fans .
Best of luck . :-)
God bless
Wyr
Old 01-25-14, 04:31 PM   #10
How did you lose oil and gas?
