Old 12-10-13, 03:18 PM   #1
brogsie
Default Clean the filter on your mini split
My mini split was not putting out the heat like it was last year. I wondered if it was leaking freon. I opened up the cover of the inside unit to look inside. The air filter was clogged with fine dust. I took out the filters, cleaned them up and reinstalled. The unit is pumping out the heat now. I will have to clean the filters on a regular basis. If you haven't cleaned yours I would check them out.
Old 12-11-13, 04:05 PM   #2
You might want to check the filter fit too.. Mine were letting air (and dirt) get around the edges..
http://ecorenovator.org/forum/geothe...ilter-mod.html
brogsie (12-12-13)
