Old 07-31-13, 09:28 PM   #1
launboy
Default Minisplit Room and Water Heater
Found this on a site that has a lot of other cool heat reclaim products for pools and domestic hot water, even a solar panel powered minisplit.
Air Conditioner Water Heaters | AC/Heat Pumps That Make Free Hot Water | HotSpot Energy LLC
A factory made version of what some here have talked about doing, and done. Competition to the super expensive Fujitsu? I believe was the brand, water heating minisplit possibly? It says up to 100 gallons of water a day, and using their stats thats 4500 btu/hr into the water. I bet if you put a bigger water HX in you could put more into water and less into the air.
Just some food for thought.
Adam
Old 08-01-13, 05:42 AM   #2
Adam,
Couldn't find a price in any of their literature . . . could you find it?
100 gallons of hot water of tepid water is easy. but a large temp increase is hard.
Old 08-02-13, 04:07 AM   #3
launboy
The specs state the cut off for water heating is 158*F. That's pretty hot for a heat pump, all though I'm not sure if that's a running temp or a safety limit cutoff. Producing that much water to 120-130* isn't hard and would be enough for space heating.
I couldn't find pricing on their site either.
Adam
