Old 11-13-12, 09:17 AM   #1
Default Turn down lcd monitor/tv backlight for 50% energy savings
Another energy savings technique i adopted.
My tv, is a 40" 5 year old LCD bought just before LED back lighted models were common.
In the tv's menu, then the sub menu, under 'back lighting', I changed the Back lighting level from level 5 to 0 (out of 10) and adjusted contrast and brightness to compensate for the change.
97% contrast with 30% brightness worked for my Monitor.
Savings results:
102 watt usage before
50 watts after adjustments
Last edited by ecomodded; 11-14-12 at 12:16 AM.. Reason: Reduced and reduced once more
FortyTwo (11-15-12)
Old 11-14-12, 06:36 PM   #2
Nice energy savings. I do this with all my monitors. It works great.
