Old 06-29-12, 11:01 AM   #1
MarkM66
Default Exterior home shading
I'm looking for ideas to block sun from the southwest windows of my home. I have about a 20' span of windows on that side, and in the afternoon/evening, they let in bunch of sunlight. I currently don't have any window coverings on the inside, as I like that clean look.
My area is having a record breaking summer already (it was 109F yesterday), so I'm looking for ways to keep my home cooler.
I'm thinking of some sort of lightweight, track type system that I can hang from the outside edge of my soffit, which would place the shade about 2' from my windows. I like the track idea, so I can completely slide in out of the way when not needed, or slide the material out of the track before a storm/winter, etc.
Any ideas would be appreciated.
MarkM66 is offline   Reply With Quote
Old 06-29-12, 11:45 AM   #2
Solar screens have a pretty clean look and work extremely well.
http://ecorenovator.org/forum/renova...n-project.html
FortyTwo (09-07-12)
Old 06-29-12, 12:36 PM   #3
Some form of roll up shade would probably work good too (on the exterior). I'm not sure how asthetically pleasing you want it to be though.
Old 06-29-12, 01:22 PM   #4
MarkM66
That looks good. How did you attach the screen to the window? Are there mounting tabs that come with the kit? Screw in?
Old 06-29-12, 02:29 PM   #5
S-F
You Ain't Me
S-F's Avatar
There is a recent GBA article on keeping cool and they make the good point that shades on the outside work better because they don't let the heat from the sun enter the house.
My project:
Old 09-06-12, 05:30 AM   #6
adina728
Nice Post....Thanks for the info.
adina728 is offline   Reply With Quote
