Old 05-16-11, 01:51 PM   #1
Default Brazing copper for HVAC?
Brazing copper seems to need very high temperatures..
What kind of rig would be good for small scale hacker apps?
I like this one, ($320 +$26 shipping).
GENTEC Light- to Medium-Duty Cutting/Welding Kit, Model# KA-51-TCPW | Cutting, Heating + Welding Torches | Northern Tool + Equipment
But, this one,
is only $60 at Home Depot..
Bernzomatic Multi-use Tote Torch - OX2550KC at The Home Depot
I've read it's hard to get the right mix with these valves..
More Oxygen bottles are about $8 at Lowes, when in stock..
And, what is an "Air-Acetylene Torch"??
Sears: Online department store featuring appliances, tools, fitness equipment and more
Thanks for your comments,
Rich
Old 05-16-11, 03:34 PM   #2
Does map gas alone not get hot enough to braze for HVAC?
Old 05-16-11, 03:52 PM   #3
I'm not sure. It might be borderline for larger than 1/2 copper lines.
I've used MAPP gas before, when installing hotwater solar using 95/5 solder (95 % TIN) on 3/4" copper pipes and fittings.
But, after watching some videos of HVAC braze jobs, I can see the pipe and fittings glowing cherry red..
The filler metal used on a lot of those jobs, was 15% silver and 85% copper. (Very costly stuff).
If I decide to DIY a heat exchanger, then it's doubtful MAPP alone would be the way to go..
Old 05-17-11, 09:41 AM   #4
Found a brand name rig (I think) at:
Victor 0384-0936 Genuine Portable Torch Cutting Welding
Some sticks on Ebay:
HARRIS STAY-SILV 15 PHOS-COPPER SILVER BRAZING ALLOY - eBay (item 220782605610 end time May-18-11 10:14:36 PDT)
Is Victor a good brand?? My few welder friends aren't giving me much information.
They own the large (non-portable) gear, purchased used..
Old 05-17-11, 10:27 AM   #5
Brazing copper seems to need very high temperatures. What kind of rig would be good for small scale hacker apps?
I am not a brazing expert, but I will share my very modest experience...
I'm using just a MAPP gas torch, no oxygen. I have tried just propane and it just barely got to cherry red... very frustrating.
When I switched to MAPP, it worked much better.
You probably already have a propane torch, you might try getting a bottle of MAPP gas and running it that way. If it doesn't work, you have a spare bottle of MAPP gas.
Tricky part is that the cherry-red temp is not so far from the slump temp of copper... so you don't want to go too hot.
You may be right, straight MAPP gas might be borderline on larger tube like you have... you'll need to do some tests. Whatever setup you get, you should practice on something that is similar to the piece you're trying to braze. Do several tests... If you use up a whole bottle of gas doing tests, it is money well spent.
You sure don't want to combine plumbing solder & brazing rod, they don't mix, very bad... I know... I tried it once... never again.
I have had the best luck with SilPhos rod. It is self fluxing, flows very nicely.
SilPhos is available in 5% silver (which I use) and 15% silver (which the HVAC trade seems to prefer). I haven't tried the 15% stuff because it's more expensive, but I assume it has a slightly lower melting point, which would be good for you.
Before you braze, you should see if you have any positive pressure in your unit at all. If you don't it means that the R-410a has all leaked out, and you can assume that the unit has been"breathing" (my term) air and moisture in the meantime, so you should pump down and purge with inert gas a few times before you braze (principle of dilution).
If you have any measurable pressure, you can assume you have enough R-410a to prevent "breathing" so you don't need to purge... but you may need to release some pressure...
One of the warnings of running nitrogen (or other inert gas) while you braze is that if your nitrogen pressure is too high, you will get pin hole leaks. So this may be why you have the pinhole leak you have.
When I braze, I run enough of my inert gas to purge the system, and I provide an escape for the gas, to which I attach a tube that I then insert a few inches into a jar of water. This way, I am assured that I have a continuous flow of purge gas AND I know that I am not building up any significant pressure. I adjust my purge gas flow rate so that I get a bubble every few seconds... so the flow rate is very, very low.
You should ask at a welding shop what kind of rod you should use to fix an existing pinhole leak in a new unit, such as you have. They may even recommend 40% or 60% silver. (If you think 5% or 15% is expensive, wait til you price this stuff!!) BTW, my experience is that the guys who work the counters at welding supply shops (not the big box places) are VERY knowledgeable and helpful, and they understand that the good advice they have is part of their service. Very different from the HVAC trade...
SInce you are not trying to join dissimilar metals, I wouldn't think you'd need flux.
Since the price of rod has gone so high, some places sell what they call "job packs", which is less than a pound, and only has a few sticks (which may be all you'll ever need).
You may also want to isolate the high temperature from the rest of your unit by wrapping wet rags around the tubing. You don't want to get too close to the joint you're working on, you'll make it too hard to heat up.
P.S.: Be aware that brass fittings have a LOWER slump temp than copper...
Old 05-17-11, 03:07 PM   #6
I have one of these http://www.bamboocraft.net/workshop/...eTorch-035.jpg
and a full bottle of MAPP gas. So, I can do some testing on scrap copper.
I have to pull off a short section of tube, (it held the thermistor).
And then seal up the tiny pinhole right here:
Yes, "the unit has been"breathing". I assume it's full of moist air, that's being sucked in and out of the pinhole.
This tube seems to be the output line of the compressor.
Thanks for the water bubble tip on the nitrogen flow. I'm going to need it.
Otherwise, the filler metal will just bubble right out.
Due to the hole, I will not be able to vac the system at all.
That will just pull more wet air into it. (I hope it stops raining some day)..
I've heard about protecting parts from torch heat using wet strips of cotton from old t-shirts.
I'm a bit familiar with process, due to all my DIY plumbing work..
I've watched some videos, and it seems like a really hot flame directly
on that pin-hole area would get it cherry red very quickly.
When the loose tube fell off, all I would need to do, is quickly melt some filler on top of the leak area..
But, looking at where the leak is located, I might not be able to reach in there with the torch.
Dang! Looking at this picture, I'm really thinking seriously of trying to find a welding shop that will braze this for me..
Old 05-17-11, 07:35 PM   #7
Default 15% Silver!
I found those little Job-Packs at HomeDepot.. Cheaper than Ebay for 8 sticks..
Harris Products Group Stay-Silv 15 Sticks (8-Pack) - 1520FMPOP at The Home Depot
Gotta order two for free shipping..
There's a 4 pack for $15 shipped on Ebay..
4.4 OZ. SILVER BRAZING SOLDER RODS 5% 15% 36 IN. LONG - eBay (item 200609174825 end time May-21-11 21:03:50 PDT)
Old 05-18-11, 03:55 AM   #8
S-F
You Ain't Me
S-F's Avatar
FWIW I have the small kit from Home Depot. I got it for doing exhaust work on the car. For cutting. I would be very careful with oxygen and mapp since it cuts a steel exhaust pipe pretty easily. I imagine it would make pretty short work of a copper tube.
Old 05-18-11, 11:19 AM   #9
lstaz66
Hey guys...Just wanted to add to the post if ya dont mind ?...Xringer..Its best you use Ox/Acetylene..Home Debot has a rig for $289.00 .Also you can use Silphos,FYI..You can probablly go to a local a/c wharehouse and buy single sticks,Instead of Packs.
I would pump down the system before Braizing the leak. If possible ?..Recover the refrigerant first..Braze leak..and vacuum down the system...Just a thought !!... I am in HVAC School learning the trade..By no means am I an expert..Funny thing..We are Braizing Now..Pretty cool stuff..And BTW ! Ya dont need the copper cherry red ! Oxy/Acetl. Gets hot pretty quick...When the flame is on the copper..The copper will turn kinda white...At this time ya wanna start your braze...
The Silphos when melted(Like water) will follow the heat..You can move it around your fix pretty easy....Good luck !!
lstaz66 is offline   Reply With Quote
Old 05-18-11, 02:05 PM   #10
Thanks for posting.. Can't pump it down, it's got a pin-hole, that would suck
in more moist air.. I plan to do that after the leak is repaired..
I need to get some more nitrogen, so I can flush out the air while making the repair..
I found the Home Depot rig on-line ($299.98 here)
and can't tell too much about it. I'm leaning towards getting the Victor
Since it's a brand name and I'll be able to get spares..
The Lincoln Electric Port-A-Torch Kit from HD can't be found on the Lincoln
Electric website.. And, there aren't any reviews around for it..
I'm going to try to get about 8 oz of Silphos sticks off Ebay.
So, I'll have some to practice with and maybe enough to do some hacking.
I'm also looking at a "VICTOR STYLE HEATING NOZZLE" at,
VICTOR STYLE HEATING NOZZLE ~ 4-MFA-1 for 100 Series - eBay (item 320688366136 end time May-20-11 04:02:50 PDT)
that will fit the Victor kit above.
It might work better than using the small cutting(?) tip that comes with the Victor kit.. Looks like a shower sprinkler head tip..
Maybe help out when trying to heat up 1/2" copper fittings..?. What do you think?
What kind of tips are you using in School??
Thanks,
Rich
