View Poll Results: Do you use your ceiling fan in the winter?
Yes 10 55.56%
No 8 44.44%
Voters: 18. You may not vote on this poll
Old 10-15-08, 11:08 AM   #1
Default Using ceiling fans during the winter
How many of you use your ceiling fan during the cooler months?
If you run your ceiling fan so it blows upwards you don't get a cool draft over you, but still mixes up the air in the room. With the fan on its lowest setting, you use very little energy and gain a few degrees in the room you are in.
Here is some testing that was done on builditsolar.com. As you can see, he has tons of heat just sitting up at the top of his room.
Thermal Stratification With High Ceilings -- A Test
Old 10-15-08, 11:38 AM   #2
insaneintenti0n
i still haven't really tried using em much. but my ceilings are nowhere near that height...
insaneintenti0n is offline   Reply With Quote
Old 10-15-08, 11:41 AM   #3
toyobug
avid DIY'r
toyobug's Avatar
hot air rises.
if your vents are in the ceiling (mine are) then you may want to run them on low.
I can tell the difference when the heat "kicks on" you feel the heat blowing around the room, that is until you acclimate to the temp change.
toyobug is offline   Reply With Quote
Old 10-15-08, 11:50 AM   #4
PaleMelanesian
PaleMelanesian's Avatar
Not really, I haven't. I have LOW ceilings, rather than high. There's not much room for a fan without getting into the head-chopping region. With higher ceilings, I'd certainly give it a try.
Old 10-15-08, 12:20 PM   #5
SVOboy
SVOboy's Avatar
That's really interesting, I'd never even thought of it. I'll have to give this tip to my mom,
Old 10-15-08, 12:22 PM   #6
If you check the bottom test (there are two) its for a room with a much lower ceiling. Once the fire place is lit up, there is a HUGE difference between 1' and 8'. As you can see, with radiant flooring the temperature is fairly uniform.
Old 10-15-08, 03:48 PM   #7
groar
X-Frenchy: very
groar's Avatar
Our ceiling fans have been installed this summer, so it will be our first winter with ceiling fans. They can rotate in both directions so I note this idea and we may try it when we'll have to heat again.
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Old 10-15-08, 07:52 PM   #8
dremd
Need More Eco
dremd's Avatar
Ofcourse I do; I use them whenever the A/C is running :-)
No Seriously I reverse them whenever it gets cold (<65F). (Still running A/C here)
The Following User Says Thank You to dremd For This Useful Post:
sofi53 (10-25-13)
Old 10-16-08, 07:23 AM   #9
cmittle
I haven't before, but I can tell you that I will be getting the ladder up and switching the fan in my living room this afternoon. I'm going to give it a shot.
Thanks,
Cory
cmittle is offline   Reply With Quote
The Following User Says Thank You to cmittle For This Useful Post:
sofi53 (10-25-13)
Old 10-24-08, 07:25 PM   #10
truckncycle
We don't even use the ceiling fan in our bedroom in the Summer.
truckncycle is offline   Reply With Quote
The Following User Says Thank You to truckncycle For This Useful Post:
sofi53 (10-25-13)
ceiling fan
