Old 09-09-10, 07:54 AM   #1
Default Solar Beats the Bank
I found this and had to share. Apparently investing in solar power pays back much better than putting your money in the bank at 4% interest (which does seem low). You NJ people better jump all over this.
Solar Beats the Bank | Buy Solar Panels for Your Home – 1BOG Group Solar Power Discounts
Old 09-09-10, 09:14 AM   #2
RobertSmalls
RobertSmalls's Avatar
1. The uniformed plug-footed giants marching in unison are a bit intimidating.
2. They are claiming an annual rate of return (ARR) of 3.53% for the savings account (they blatantly cheated!), 5.15% for SF, 7.99% for LI, and 8.87% for NJ.
3. Will a balanced portfolio of stocks, bonds, and savings outperform the above ARR's? I don't know, but 8% is not bad in current economic times.
4. Parents of a newborn infant do not tend to have $20k lying around to invest in a lump.
5. I conserve electricity. How will this affect what I save by going solar?
Don't take financial advice from an infographic. Do the math yourself. It looks like a solar system is a bad investment in the absence of market externalities, but incentives can push it into "good" territory, provided you don't sell the house. I doubt it would add anywhere near the installation price to the value of the house.
Old 09-09-10, 09:33 AM   #3
All very good points. There is a lot of missing (and apparently bad) info in the graphic. I agree 8% is a good number. At 8% you'd be at ~$86k after 20 years. So, it does go to show solar can be a viable investment under the right circumstances. Those circumstances would definitely need to be evaluated before plunking down the cash for a PV system. Actually a solar hot water setup is a much better investment as the ROI is much quicker.
Old 09-10-10, 09:21 AM   #4
trikkonceptz
The only flaw I see in this logic is that aside from investing in your home, you would have to have the discipline to put the savings away yourself, and therein lies the problem.
We are not taught to save and would therefore construe the savings as extra cash to spend on the BS we accumulate. Now if there was a program that once you went solar the energy savings based on previous non solar year costs would go into the bank, then yes this would work out great.
Otherwise, very few of us would ever see that money in any amount worth writing home about. It's a shame.
trikkonceptz is offline   Reply With Quote
Old 09-10-10, 12:48 PM   #5
benpope
benpope's Avatar
Even if you didn't save it, you would presumably get the benefit of being able to spend the money on something other than electricity.
Old 09-10-10, 10:09 PM   #6
Just curious, how did that happen?
The only way I can see PV being a good investment, is one of three things:
1. The price of installing a few KW of PV on your roof drops by a factor of 10.
2. You are living off-the-grid, because the power company wants $96,000
to run power lines to your home in the boondocks..
3. Cap-n-Tax passes, CO2 is outlawed & etc. / government bureaucracy
increases the cost of a kWh to 96 cents.
Old 10-07-10, 08:45 AM   #7
st2288
I was one of the lucky ones to take advantage of the LIPA (Long island power authority) last year solar program. They offered $3.50 watt rebate. After all the rebates (fed and state). I paid less than $1.00 a watt INSTALLED!!.
This year LIPA offered $1.75 a watt and it went out of money for the program a few times already.
So far I banked over 900kw since April. I should recoup all my initial cost in 4 years or less. I didn't figure it the cost of heating since I will using split air heat pump. It will be a lot faster when I figure out after this heating season.
After 4 year, I will be making money on this (min $150.00 a month providing the elect. rate stay the same $.21 KWH) not counting the heating cost ($3.00 a gallon of heating oil).
The bottom, at least for me, it is better than any investment out there. Plus I eliminated over 13,000 lbs of carbon in 7 months.
st2288 is offline   Reply With Quote
Old 10-07-10, 11:18 AM   #8
strider3700
at $1/watt installed I'd be on the phone screaming to get it done right now. There are almost no incentives up here though so installed price is much closer to 10 times that the last time I checked.
Old 10-07-10, 06:39 PM   #9
Agreed! $1/watt is crazy cheap.
