Old 09-04-10, 04:27 PM   #1
Patrick
Default White Seal Roof Coating to Lower Attic Temperatures
I decided to try some white roof coating to lower my attic temps and therefore hopefully lower my AC power consumption. My shingles are a very dark (not black, but close) asphalt type. I bought White Seal from Home Depot as the coating material. It's Energy Star rated and warranteed for 10 years. I bought it in the 5-gallon containers @ $64 each as that was much cheaper than by the gallon.
I didn't take attic temps before I started, but later I found my infrared thermometer and took some temps on the roof and at the attic vent.
The temp on the roof itself at 12:00 with full sun yesterday was 104F on the coating and 155F on the bare shingles.
Ambient was 88F and the attic outlet temp was 90F. My latitude is 36 degrees N.
The air conditioner seems to run less than before. Next year I'll be able to report on the difference in kWh used.
Name:	Temp of Bare Shingles 155F.jpg
ID:	910   Click image for larger version
Name:	Temp of Roof Coating 104F.jpg
ID:	911   Click image for larger version
Name:	Temp at Attic Vent 90F.jpg
ID:	912   Click image for larger version
Name:	Ambient Temp 88F.jpg
Old 09-05-10, 08:34 AM   #2
Wow, if the attic is only blowing out 90F air and the white shingles are only 104F that is AMAZING vs the 155F shingles.
How far does 5 gallons get you sq/ft wise?
Old 09-05-10, 08:44 AM   #3
Patrick
I would say about 30 sq ft/gallon, or 150 sq ft/5 gallon bucket. I might have put it on too thick, though. I hope the 2nd coat won't require as much material.
Old 09-06-10, 03:53 PM   #4
trikkonceptz
Would you photograph the entire home with roof view once you are done? Here in S. Florida, we have to deal with alot of issues, county, HOA's and such and seeing photos of what a completed roof looks like it better than describing a "White Roof" on a house that normally has darker shingles..
Thanks ..
trikkonceptz is offline   Reply With Quote
Old 09-06-10, 06:09 PM   #5
Patrick
Thanks ..
OK, but I'll probably have to get on a ladder. You can't see the roof from the street. Only my neighbors with 2 or more story homes or decks can see it.
Old 09-07-10, 10:15 AM   #6
BTW, I just remembered. I had found something similar to this a while back. The guy used hydrated lime which I'm not sure how environmentally friendly that is but... well thats what he used. His results were fairly impressive too.
http://ecorenovator.org/forum/conser...0-degrees.html
Old 09-07-10, 12:52 PM   #7
benpope
benpope's Avatar
I am impressed with the results. I have a 1000 sq ft portion of my roof that is nearly flat and a good candidate for painting. However, for the visible parts, my wife won't go for a bright white roof. I realize that white reflects more visible light than any color, but are there any reflective roof paints that come in colors other than white? Discounting visible light, there is still plenty of energy to reflect in the UV and IR band, so there has to be something. File:Solar Spectrum.png - Wikipedia, the free encyclopedia
Old 09-07-10, 10:55 PM   #8
Patrick
It's tough to get even close to white: http://www.azcoolroof.com/downloads/...g%20Materi.pdf
Old 09-07-10, 11:23 PM   #9
Patrick
Wait, here's one: Planet Supra Thermal Barrier Paint
The Following User Says Thank You to Patrick For This Useful Post:
benpope (09-08-10)
Old 09-08-10, 08:28 AM   #10
benpope
benpope's Avatar
Thanks- those look good. Now I just have to figure out how to pay for it. :-/
attic, roof coating, white roof
