Old 03-02-16, 01:23 PM   #1
pinballlooking
pinballlooking's Avatar
Default Raspberry Pi 3 Model B is now out
Pi 3 is out built in Wi-Fi, and Bluetooth Low Energy (BLE) on board...
It looks good to me I just ordered one. Same price $35
http://www.newark.com/buy-raspberry-...JAMaArQo8P8HAQ
Adding Wi-Fi is a big deal.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 03-07-16, 06:57 PM   #2
pinballlooking
Here are some performance test for the new Pi 3
Raspberry Pi 3: How much better is it than the Raspberry Pi 2? - TechRepublic
EV Chevy Volt -
Old 03-12-16, 08:05 AM   #3
Fordguy64
What do plan on doing with it?
Old 03-13-16, 08:03 PM   #4
pinballlooking
The plan is to use it on my Aquaponics System. http://ecorenovator.org/forum/lawn-g...-build-61.html My new heat exchanger needs to only run if the fish water is below an 82 F and the peak of the roof (where the heat exchanger is) above 90 F. this does not need to be ready until next winter.
EV Chevy Volt -
Old 04-04-16, 11:36 PM   #5
NiHaoMike
NiHaoMike's Avatar
I got one to use as part of an altcoin mining setup and it definitely heats up under load! You'll definitely want a heatsink on the CPU.
https://www.loverpi.com/blogs/news/9...portant-notice
Old 05-20-16, 01:45 AM   #6
Maire1942
Guest
Posts: n/a
I've been looking for this new model ....thanks for sharing
