06-23-15, 02:50 PM | #1 |
Another Mini split install
This forum has helped me tremendously. I probably would not be installing this unit were it not for some of the threads on here. So this is me giving back.
I am installing a 12k btu pridiom 20 seer heat pump on the first floor of my south philly row home. approx 500sqft I considered 9k btu, which would probably have worked but I wanted the extra heat capacity. I also figure that the bigger unit will help draw some humidity out of the basement which would be a big plus. So far the indoor unit is in, and outdoor bracket is mounted 10ft off the ground. Pics to follow. |
The Following User Says Thank You to the mow For This Useful Post: | Daox (06-23-15) |
06-23-15, 03:10 PM | #2 |
Very nice I am looking forward to the pictures.
06-23-15, 03:48 PM | #3 |
Thanks for posting the mow! Looking forward to these pics.
06-25-15, 11:00 PM | #4 |
The inside unit is mounted and the outside bracket is mounted. I was originally going to epoxy anchor the bracket into the brick but the brick is soft and so is the mortar. So I cut my bathroom wall open and through mounted the bracket. Its very solid now. Notice my 3/4 plywood as large anchors.
The bracket is through mounted at the top of each leg. The middle of the legs is fastened with tapcons. Pridiom recommended 12" clearance behind the condenser. I was not able to find a premade bracket that was 22 (condensder is 10 deep) inches deep so I made one out of 3/16 2x2 angle iron. Last edited by Daox; 06-26-15 at 08:20 AM.. |
06-26-15, 01:20 AM | #5 |
Nice start on a good project.
If you wanted to include in-line images, you can use the "picture of a mountain" icon on your edit bar. Best, -AC
07-14-15, 06:35 PM | #6 |
Once you get the hole in the bathroom wall repaired with dry wall , hang a mirror or picture over it . :-)
God bless Wyr |
07-20-15, 10:55 PM | #7 |
Finally got around to finishing the job last night. Wish I had taken pictures of my vacuum setup but when its 90 degrees and youre pouring sweat while 10ft in the air, I decided not to ad any steps.
Turned the unit on at 11pm last night the room was 91. Went to sleep and the room was 68 this morning So here steps involved from my last post. Mount the outside unit on the bracket. 88lbs 10ft in the air with just an extension ladder was not fun or safe Run conduit outside and up the wall to the water tite disconnect. House is 2 rows of 4" brick with a 1" air gap between the rows. I only had a 1"x16" sds bit which was just a bit too small for 3/4 pvc conduit. Had to bore the hole out for a while to get it big enough. Next was the lineset running. My unit came with 25ft of linesets which were too long so I had to cut them down. I bought the yellow jack flaring tool 60278. Cut, debur, nylog everything, then flare The tool had great reviews but I had less than a great experience with it. When screwing down the flaring cone, its easy to go just a bit too far. This results in a ridge down the face of the flare which will cause a leak. I didnt notice this ridge until my last flare. Needless to say I was very frustrated. There are other flaring tools available that have a clutch in them. Takes the guess work out of how much to tighten. I remade 3 of my 4 flares and hooked up my nitrogen setup and pressure tested to 300 PSI. I checked all connections and found no leaks. In hindsight, I wish I had left the returning line flare off and purged the system with nitrogen for a few minutes. I believe I could have gotten a better vacuum on the system. Then I hooked up my vacuum pump micron gauge. I got the system down to 325 microns and valved off the pump. It rose to 525 and stopped. This was good enough for me. Plus is was 1030pm on a sunday night. The outside unit is very very quiet and the inside unit is about as loud as my refrigerator. I have the temp set to 75 right now and the first floor is very comfortable. The inside unit display shows the compressor frequency. There are 5 bars that can illuminate 1-5. I think that more load is more bars? Since this is an inverter based unit?? |
07-20-15, 10:58 PM | #8 |
Here are the pics. Will add more
07-21-15, 03:15 AM | #9 |
Congrats ! :-)
God bless Wyr |
07-22-15, 01:59 PM | #10 |
Great Post. It really helps to hear real world reviews of products.
Also, amazing price! I can't believe that! |
