#1 |
![]() I had seen this before and forgot about it but stumbled across it again today. An Australian man converted a chest freezer into a refrigerator. He claims it uses only .1 kWh per day! To compare, my chest freezer uses almost 1.3 kWh per day, and my fridge is just a little less I think.
http://www.builditsolar.com/Projects...est_fridge.pdf
#2 |
![]() It's a really good idea, but I think implementation is limited by the human body, and peoples comfort in getting at their milk and soda. Maybe the basic concept can be applied better to new fridge designs though?
#3 |
![]() I think the basic ideas of more insulation and it being a chest type instead of upright are the only real advantages. They just happen to be huge ones. I'm not sure how much the refrigeration system has to do with it.
Current project - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Daox; 12-01-08 at 02:03 PM.. |
#4 |
ECO Blogger & DIY'er
![]() Woah, thats impressive. Funny how such a easy thing as moving the door to the top can do such difference. (First page of the pdf.)
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#5 |
![]() What if you tool an old school Fridge ( top freeezer - standard doors) - and "mounted" it on its side with the door opening UP?
could you capitolize on the DOOR advantage and have FRIDGE and FREEZER? we were thinking of tgetting a "scratch and dent" fridge for garage - maybe i will try this and see if it cools better than upright would.... steve
Steve AKA Doofus |
#6 |
![]() I would avoid this. You want to be careful how refrigeration units are placed, because the refrigerant can slosh around and get into parts of the system it's not supposed to be and this can cause pumping problems for the system. Most refrigerators even suggest leaving them unplugged for up-to 24 hours after simply moving them. Laying them down is a big no-no.
#7 | ||
Home Improvement Goon
![]() Quote:
![]() We need a better "tongue sticking out" smiley. |
#8 |
![]() I found this page (thanks to Gasper
![]() Low power chest refrigerator The difference here is that the fridge has thermal mass inside. Not just bottles of water like everyone does, but bottles of olive oil. Why? Because olive oil freezes at refrigerator temperatures, so the phase change stores more thermal energy than water does at that temp. This allows the compressor to be turned on only once a day for 30 minutes. I started a new thread on phase change materials to keep this thread from getting too far off topic.
#9 |
![]() Is that reduction in power usage due to less often cycling of the compressor, or simply due to a little better insulation or a more efficient compressor?
I love the idea and the phase change material info is great! But, I have my doubts that that is exactly why this one is more efficient than the other. It is a great idea for say PV use or time of use people. PV users could run the fridge during the day and time of use users can run their fridge at night when they pay less and go all day/night without it turning on. Even if you're not on time of use, it still would reduce peak usage which can help reduce peak power plant output which drives down costs for everyone.
Tags |
efficient, refridgerator |
