01-14-12, 03:16 PM | #1081 | |
The model you choose is an air conditioner only and uses an electric resistance element as it's heat source. Your chosen model has a 1700 watt resistance heater and at 115v the element would draw 14.78 amps. Your chosen model uses 17.7 amps total when heating. That would leave 2.92 amps to do something else with... I bet that is to power the fan... don't you think? If you look further down the chart you will see that some model's cooling current use is much closer to the heating current use which indicates that the compressor is operating in heat pump mode and also notice that being figured into heating amps is current draw when BOTH the heat pump AND resistant heat is being used simultaneously. -AC_Hacker
01-15-12, 12:22 AM | #1082 |
I agree with AC. Making something do what you want it to do by re-purposing it for a few dollars is a wonderful thing. It's just that seeing these marine units with all the parts already there for a medium cost is exciting. Using old ACs or water coolers to help heat a shop or some other living space is cool (sorry - I couldn't resist).
01-15-12, 12:48 AM | #1083 |
We were lucky to get a hold of a Trane water source heat pump for $1200. 24000BTU unit with top discharge air handler.
http://www.climas-trane.com.mx/docum...a%205%20TR.pdf I'll post pictures of HP later. it won't suffice for our size house but we look forward to the challenge - being our first time doing this. Hopefully I can post updates of project as it progresses. |
01-15-12, 09:48 AM | #1084 | |
But this thread is actually about re-purposing or refashioning existing HVAC units for your particular purposes. In fact that is why it is explicitly named Homemade Heat Pump Manifesto. The Homemade part of the name really says it. If you wish to share the installation of your Trane water source heat pump, you should start another thread at the 'Geothermal' level of the forum tree. Starting a new thread is very easy, just click the 'NEW THREAD' button, and you are on your way. There have been lots of other folks who have created their own thread(s) and shared their install projects. Many of our users have found this contributed information to be of great interest and in some cases, imminently useful to their own related projects. Good luck to you with your new thread and your new project. Best Regards, -AC_Hacker
01-15-12, 01:39 PM | #1085 |
Fair enough. Keep up the excellent work demystifying geothermal technology and sharing your experience so others can be inspired and and also share.
Thumper |
01-16-12, 01:04 AM | #1086 | |
BradC a HVAC hacker from Australia posted this great information on another thread... I didn't want it to go unseen.
01-16-12, 11:15 AM | #1087 | |
01-16-12, 12:38 PM | #1088 |
You are off-topic...
Please start a new thread for this conversation... This conversation is not relevant to the homemade heat pump topic. -AC_Hacker
01-16-12, 06:06 PM | #1089 |
Vacuum Pump on Sale...
This was just too good to pass up...
I have one of these... It works just fine. Probably will not hold up to professional use, but for experimenter's use it is just fine. With fresh oil, mine will go down to 60 microns. Good enough for me. Print this coupon... -AC_Hacker
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 01-16-12 at 06:13 PM.. |
01-16-12, 06:45 PM | #1090 |
Never underestimate the value of fresh oil. Another thing I stumbled on recently is running the pump in under heavy load. (I didn't know they needed to be run in, or could benefit from it).
Mine pulled to just under ~200 microns. I'd used it on and off over an 18 month period, but never for more than 4 or 5 hours at a time and always pulling a high vacuum. Recently I learned that vane pumps need running in, and need to be run *hot*. I put a ball valve on the input and throttled it back to just a trickle of air and let it run for 24 hours. I then changed the oil, did it again, closed the valve completely and let it run another 24 hours (total of 3 days). It now pulls a 37 micron vacuum. If you want to pull a good vacuum, run the pump for about 1/2 hr loaded with a trickle of air to get it good and hot before you hook it up to the system. More so if the system has moisture in it as the hotter the oil, the less it loads up with moisture. (Tried to respond to your PM AC_Hacker, but I don't have enough posts yet. Thanks for the message. More to come!) |
Tags |
air conditioner, diy, gshp, heat pump, homemade |
