09-27-11, 03:55 PM | #1 |
Privacy window and thermal barrier
In the finished part of my basement we have two windows that are sealed close and I have now added spray insulation in the empty gaps around them. I have been wanting to make it hard to see through but let light in and was thinking about using spray window frosting, but when I was at the hard ware store I got the idea to use the plastic covers from overhead florescent lights.
I figure I can difuse the light build a small frame and have an air gap to add insulation like in these threads. http://ecorenovator.org/forum/conser...m-windows.html http://ecorenovator.org/forum/conser...or-storms.html The issue is that I have not been able to think of how to attach the cover to the window as I do not think I can just stick something to the spray foam, and the box around it is cement with a wall made of paneling over the cement. The top of the paneling is open to the drop ceiling. I will have to get pictures up to show how it currently is but in the mean time wondering if any one has suggestions? |
10-05-11, 10:38 AM | #2 |
Did you ever get pictures of this? Its hard to tell what you're talking about just from the description.
10-06-11, 01:47 PM | #3 |
No I have not I keep forgetting and have been getting home late and working extra hours.
10-17-11, 07:51 PM | #4 |
I finally got to taking the pictures.
I will be cutting the extra foam off soon and it will be flush with the frame of the window. |
10-17-11, 08:27 PM | #5 |
How about gluing it on with Peal-n-seal caulk? it's not going to look pretty enough to have in your living room but the peal-n-seal caulk I have is clear and is designed for sealing storm windows that get removed in the spring.
I would leave some small weep holes open at the bottom unless you put the plastic in place on a very dry day. |
