08-22-12, 05:07 PM | #1 |
PID Temperature Controller
PID stands for proportional–integral–derivative and is a way to apply optimized feedback to reach a desired target, be it a temperature, volume, speed, or even an enemy naval vessel. It will maintain a temperature with great accuracy, too.
I found a really cheap one on ebay for about $25, free shipping, so I thought I'd investigate. It took so long for it to arrive from China that I forgot that I had ordered it, but I still remembered that I wanted to get one and was about to order, when the package turned up in my mailbox. The product and the enclosed document were all in Chinese, but there was the model number written on the controller: XMT7100 I looked through the Internet for a reasonable manual, found a lot of poorly written ones, but finally found a good one LOCATED HERE. The controller needs voltage (110v to 220v) not only to work, but also to set it up for your application. Here is a diagram in the manual which includes the 'pin out' (screw-out?): I scrounged an old lamp cord & plug and connected to screws 1 & 2 (if you look at the screw area, there are numbers near each screw). I used small crimp-on spade connectors to avoid any nasty shocks. Now the unit will light up and the menus can be investigated. When you push the SET button, the numbers will all turn to blinking zeros, the ">" button will let you step from number to number. The '^' button will let you increment the digit you are on, and the 'V' button will let you decrement the digit. The codes to get you into the various menus are:
To get into a particular menu,
Once in the menu, various choices are available to you, and each menu includes a choice called 'END' which allows you to exit a menu. The diagram below, is in the manual and is supposed to explain all of this to you. Hopefully, between my description and the manual, you'll have no problem. The controller will allow you to use an auto tune feature that will automatically go through a brief test cycle and set the optimum PID coefficients for best operation, based on the heat output of your heat source, and the thermal mass of your system. The auto tune function is initiated by pressing the '>' button for more than 3 seconds, at which time the small LED on the left side of the display begins rapidly blinking. When the test phase is complete, the LED returns to normal operation. So, if your heat source or the thermal mass of your system change appreciably you should run the auto tune feature again. I sketched out a hasty wiring picture: And wired it up to a small water heater to use as a Sous-vide egg cooking experiment. Again I used crimp-on insulated connectors: After I ran the auto tune function, I put my egg in for one hour at 65 decrees C. The controller will rapidly increase heat to the set point, not overshoot, and with brief pulses of electricity, hold the temperature dead on. It will remember its settings when unplugged. The controller has a built in relay (screws 4 & 5) that is designed to operate a visible or audible alarm if some set point is reached. That set point is programmable via the menu system. The set point can be established to be at the target temperature, at a higher temperature, or at a lower temperature. The relay, though designed as an over-temperature alarm, can be used for other interesting purposes, for instance some folks have used it to activate the water pump in an espresso machine, so other uses may come to mind. The main output of the PID (screws 9 & 10) is a pulse of about 4 volts, low milliamps, of PID controlled variable-duration, that is designed to turn on and off a relay, or better yet, a solid state relay. In the early part of the warm-up cycle, the pulse is fairly long duration, as the controller approaches the target temperature, the pulse width begins to get shorter, and when the target temp is reached, very brief pulses precisely maintain the temperature. If you get a PID controller, you'll likely want to get a solid state relay, too. I got a 25 A 220v SSR, from ebay for about 6 or 8 bucks, free postage. I bought four of them. You'll also need a thermocouple. I already had some K type thermocouples laying about. My controller will also ten different types of thermocouples, so you'll need to carefully read the specs on the controller you choose. I'd say that a thermocouple with a three foot long cable would be better than the one that I have with a two foot cable. BTW, of you plug the thermocouple leads in backwards, the temp readings will go down when they should be going up... just switch the leads. Uses:
It's a fist full of technology for $25. Incidentally, the 65 degree egg was delicious. -AC
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 08-22-12 at 08:53 PM.. |
08-22-12, 06:33 PM | #2 | |
08-23-12, 08:32 AM | #3 |
These look very similar to devices produced by these guys but prices through other sources seem much cheaper. I'm not sure if they are made by the same manufacturer or not but they look pretty much the same.
Lightobject.com Sacramento (Elk Grove) DSP CO2 laser machine & Parts. Solar panel & Electronics Supplier all of Northern California |
08-23-12, 10:00 AM | #4 | |
Interesting line of stuff. Probably don't have to wait for months to get what you want. -AC
08-23-12, 10:41 AM | #5 |
Nice explanation of the Auto-Tune. I like that it can learn to be smart enough to sneak up on the set-point,
and not just plow right past it.. A PID with NV settings might be just the thing for adding some aux heat to my new hotwater tank. If my A7 ASHP turns our basement into a giant beer cooler, during in the cold winter months, pumping in some extra power using the heating elements (@1200w) will be considered. Controlling the SSR's DC power with a simple room thermostat would keep power use down, when the basement wasn't real cold..
09-22-12, 12:39 PM | #6 |
Dang, no SSR pins..
Seems like I got one without SSR control..
New Digital PID Temperature Control Controller Thermocouple AC 220V REX-C700 | eBay The item description was confusing.. Trigger signal of controlled silicon: 5V/40μ S or 100mA rated current, 1A instantaneous current (self-triggering) Output signal of solid state relay: 15±3V/30mA I took that to mean it was SSR ready. Those SSR control pins aren't on mine. So, I now have another digital temperature display.. I need a display for the hot water temp, and I can use this PID's relay to drive a Low temperature alarm. (I'm going to use the smaller fish tank on left controller elsewhere). Those two displays track very close together, but the PID's sensor is slower to change.
The Following User Says Thank You to Xringer For This Useful Post: | mahmoudrumman (08-05-14) |
08-05-14, 05:44 AM | #7 | |
I have RKC rex c700 temperature controller the same that you have it is show me only sh p sc parameters and it does'nt show sl1 sl2 lck al1 ..etc parameters can you help me thank you and i will be very grateful Last edited by mahmoudrumman; 08-05-14 at 05:51 AM.. |
08-05-14, 11:58 AM | #8 | |
But, in the absence of that information, it seems to me that you could have been sent a model that is a simple temperature controller, and not a PID controller. I have purchased both. As far as I can see, the factories that make these things use the same cases and displays for each, but it is the electronic guts that make the difference. * * * Now, there is a possibility that you have the correct model, but you haven't taken the time or made the effort to come to grips with the cryptic menu system. Could that be the case? -AC
12-05-12, 11:36 AM | #9 |
Thanks for the info of the PID. Can you recommend any other application of this device? And also can you post the diagram on how you use it in your espresso machine? Just want to try it and see how it really works.
pcb components Last edited by Nellie44Militello; 11-22-13 at 10:07 AM.. |
12-06-12, 11:35 AM | #10 | |
But yes, you can use this thing to bring any temperature up to a set point (or down to a set point in cooling mode) and hold that temperature very accurately. It is a no-brainer if you are using resistance heat. If you are using something like a heat pump, you will have to be intelligent about your approach to avoid short-cycling. But the applications for this device are only limited by your imagination. So there should be no problem... Best, -AC
