Old 05-05-21, 12:20 PM   #41
I did not use hardener in my paint. It does not require it, but it takes a while to cure if you do not use it.
I have left it sit outside in the sun to help get the paint to fully cure. I put it on kind of thick and I want it to last.
Old 06-10-21, 11:43 PM   #42
Compressor is not done yet but it is closer to where it will live right beside my other compressor.
Old 08-10-23, 08:37 PM   #43
Here it is in the new shop the Emax stayed in the old shop.
This old compressor is running my plasma table grinders...
https://youtube.com/shorts/WdCdSzbGjUg
Old 11-13-23, 03:27 PM   #44
The oil pressure was low and lower when hot.
I looked up the oil that Quincy recommended you use 30 weight. I bought some Quincy oil.
that is 30 weight compressor oil. Now it is very happy I had to lower the oil pressure.
Even when hot it has great oil pressure. I will switch to using this oil.
This compressor is doing a great job running the shop.
dguzzi (11-19-23)
