Old 04-06-22, 01:48 AM   #11
Robl
I just looked up EER, SEER - as a UK person these terms have been on the edge of my consciousness for some time! We get COP and SCOP here. So:
COP (Coefficient Of Performance) is Power out / Power used. Used for heating or cooling, same units used, so is just a ratio, needs conditions (Tin, Tout stating, usually in degC). COP heating is generally COP cooling+1, if the conditions are similar - heating or cooling is often unstated, and causes confusion. For a compressor it will generally be cooling stated as this is the thermal power moved by the fluid.
SCOP (Seasonal COP) tries to use appropriate conditions for your region, and needs Tout stating. I've only seen it used for heating, but I'm in the UK:-)
EER is COP but in (Btu/h)/kW and cooling specific.
SEER is Seasonal EER.
Suprisingly I found a simple EER to SEER link in a webpage - surely this is just an empirical formula that works sometimes in some places with some heatpumps?:
EER = 1.12 * SEER - 0.02 * SEER^2
https://power-calculation.com/EER_SE...nditioning.php
Robl is offline   Reply With Quote
Old 04-13-22, 08:26 AM   #12
While an air compressor heater and a pressure drop "vortex" cooler could be construed as a heat pump with some creative marketing and/or play on words, the system is not really considered a "standard" heat pump. As the others have stated, the compression/decompression of atmospheric air is really not energy efficient.
The missing pieces are the closed loop and the condensible gas. Even a machine with no moving parts except the compressor (think deep freezer chest) can cool (or heat, think water heater cylinder) a lot of mass. Latent heat transfer is the key.
Usually there's no such thing as a free lunch, but in this case, the engineers figured one out. Its called an EVAP chiller or a swamp cooler. Please don't make me explain how that works.
