Old 06-18-14, 09:18 AM   #1
Default DIY 1000 watt wind turbine
Here is a cool DIY on how to build a wind turbine. Its not incredibly through, but its decent. It hows how to make the hub/bearing/generator, but doesn't really go into how to make the blades all that much. It has links (quite a few) to sites that have more info though.
NeilBlanchard (06-21-14)
Old 06-21-14, 03:38 PM   #2
NeilBlanchard
NeilBlanchard's Avatar
What does this output? Pulsing DC or AC? You're right, they could be a bit more thorough in their description and photos.
Old 06-23-14, 09:58 AM   #3
It looks like 3 phase AC being rectified to DC.
Old 06-24-14, 05:20 AM   #4
NeilBlanchard
Okay, that makes sense, I guess. You can't control the AC frequency, so convert it to DC. If you have batteries, then you can do a 60Hz AC inverter, or just use it as DC.
Old 06-24-14, 10:41 AM   #5
In the 1st paragraph of the instructable it says, "It's a permanent magnet alternator, generating 3 phase ac, rectified to dc, and fed to a charge controller."
I'm puzzled at their selection of bearings. They have chosen, unsealed roller bearing ("harley bearings"). These bearings are designed for a primary load that is perpendicular to the line of rotation (like a wheel on the road). However, the primary windmill load will be in-line with the axis of rotation (like a merry-go-round). Sealed ball bearings would be a better choice, and radial bearings would be the best choice to deal with on-axis loading.
Since the windmill is elevated and exposed to weather, water-sealing is crucial. Their unsealed 'harley bearing' (or any other bearing) will require precise supplemental seals to have any appreciable life.
But it looks like this is their first draft, so a second version will likely be called for in the near future.
