Old 08-10-20, 07:17 PM   #1
Default Tricks to soldering thickish wire
So, I don't work with electronics a ton, but I have soldered my fair share of things over the years. I typically use a 20W soldering iron and it seems to do darn near everything I need. However, the power wires broke on my 3d printer lately, and I replaced them with 12 gauge thin stranded wire. First off, my 20W iron wouldn't even remove those wires. It seemed like the solder was a higher temp solder than I typically use. So, I used an ancient 100W gun style soldering iron to get the wires off. I was able to reattach them with the 100W iron, but one of the wires fell off. Also, since then my 100W iron has stopped working.
So, my main question is what tricks do you guys know to get this to work well? Do I just need more heat, or is there something else I can be doing? I do use flux.
