Old 11-14-12, 08:40 AM   #41
ferg75407
120vac only for the lower element.
ferg75407 is offline   Reply With Quote
Old 11-14-12, 09:02 AM   #42
I don't use the 4.5kW elements, I just tested them, using 120vac.
Ok, I saw your link with the Airtap title and put the two together. I see what you are saying now.
Old 11-14-12, 11:20 AM   #43
Yeah, if you use 120vac, you can use a cheap timer.
The best one I've used lately is this model.
http://ecorenovator.org/forum/sale-t...-usd-ebay.html
I'm planning to use one of my transfer switches to supply inverter output power
(with a Timex timer) to one of my 'day time' loads.. Just need to hook it up..
http://ecorenovator.org/forum/solar-...project-2.html
Iota ITS-30R Transfer Switch | ChargingChargers.com
Old 11-06-13, 11:48 PM   #44
vpiya
Nice ...but if you can find many more water heaters for your house then you can go for naaptol. in which you can choose according to your requirement.
vpiya is offline   Reply With Quote
Old 11-07-13, 07:39 AM   #45
mejunkhound
Had a timer on WH for years, then poco quit the nighttime lower rate. HAve separate kw-hr meter on wh also. So disconnected timer (for use somewhere else)
Built box around wh with R25 insulation - went away for 2 weeks and only used 2k kw-hrs. Timer with insulation would gain almost nothing with added insulation.
boiler, timer, water heater
