Old 03-03-14, 03:56 PM   #551
nokiasixteth
I dont think that it ever has been below 0 here in mississippi. I believe the lowest its been was 6 degrees F.
Old 03-31-14, 05:42 PM   #552
Default Defrost Video
It's been raining here.. Seems like about 3 days.. The sump pumps are running like crazy.
Frost conditions were perfect this morning.
It wasn't very cold, so the process was much faster than when it's down in the 20s F.
Here's the boring video.. Running at 4x speed.. To keep it short..
defrost - YouTube
It's like watching paint dry in normal x1 speed..
Now it's only 1/4 as bad now..
ID:	4208   Click image for larger version
Old 04-01-14, 12:01 PM   #553
wuck
Default Yawn
Can't believe I watched that whole video. Me and 5-6 others. Just kill me now . . .
Pat
wuck is offline   Reply With Quote
Old 04-01-14, 12:43 PM   #554
Pat
All 142 seconds!! Wow!
If you watched that video, you MUST be a hacker!
I'm sure to get an award from YouTube, for the most boring video since the paint drying video..
Sorry it was so long, but at any faster speed, the falling water droplets weren't visible..
Old 12-12-14, 02:18 PM   #555
AnAppleSnail
Default "Long-term Mini-Split case study" from BSI
How many posts to share a link? I've been lurking in some of the Ground-Source Heat-Sink DIY threads, then found my way here. One of my favorite building-stuff sites, BuildingScience dot com, put out a Mini Split study in the Massachusetts climate. Here is a link to it. Otherwise, go to their web site, then Information, and pick the article.
Thank you for sharing the information on your install and its performance since then!
AnAppleSnail is offline   Reply With Quote
The Following User Says Thank You to AnAppleSnail For This Useful Post:
Mikesolar (12-13-14)
Old 12-12-14, 02:37 PM   #556
I bumped your post count up so you can post the link now. Thanks for sharing and welcome to the site.
Old 12-12-14, 02:47 PM   #557
Here's the link right HERE
Old 12-12-14, 03:04 PM   #558
That's not working for me.. This one downloads the pdf file..
www.buildingscience.com/documents/bareports/resolveuid/7f45efc07ee24ebe9c77622fe833f6fb
The 'Executive Summary' is very informative..
The Following 2 Users Say Thank You to Xringer For This Useful Post:
gtojohn (12-14-14), Mikesolar (12-13-14)
Old 12-12-14, 06:45 PM   #559
lt190b
AC Hacker, sometimes the links don't work! lt190b
lt190b is offline   Reply With Quote
Old 12-12-14, 08:38 PM   #560
I enjoyed reading that report. It is very interesting that people that did setbacks or just turned off the units then turned them back on used the most energy.
They thought they were saving energy and they had the biggest temp swings and the biggest bills.
I was very surprised how well the newer systems worked in cold climates.
This is very useful data. The power usage charts show exactly what we were all saying on my install post today. The power usage varies greatly depending on lots of different things.
