Old 08-06-09, 11:46 AM   #1
Higgy
The Gardener
Default Weatherstripping
Can anyone recommend any good weatherstripping? The stuff that I have on my door is over 6 years old, and it sucks. I close my door and it doesn't even compress the weatherstripping so it barely seels the door shut. It's the weatherstripping that came with the door so I'm looking to peal it off and put on some new stuff.
Let me know if anyone has any suggestions.
Old 08-06-09, 12:27 PM   #2
truckncycle
The open cell foam style covered with vinyl seems to work pretty well. It came with one of our doors but I know you can buy it. Our other doors have mostly the aluminum rod with the vinyl v or o gasket. It is not very affective.
truckncycle is offline   Reply With Quote
Old 08-19-09, 12:02 PM   #3
TimJFowler
TimJFowler's Avatar
For sealing around a door, I like bronze spring weatherstripping. This is the weatherstrip that comes in a roll, you nail it do the door jamb, then run a screwdriver along a seam and it springs out to seal against the door. The bronze is very durable and can be adjusted for different gaps by re-scoring the seam with a screwdriver. Use a pair of tin snips to cut around deadbolts and locks.
The foam and vinyl weatherstripping I've tried wears out and become less springy over time. I've had bronze weatherstrip on my front door for 6+ years and it works great.
FWIW,
Tim
Old 08-20-09, 12:22 PM   #4
I like the idea of bronze since it will last forever. But, I don't think it works as well as a rubber type material. The rubber will deform to fit the door exactly. This creates a great seal so you don't have air infiltration. The bronze isn't as flexible, and if there are any irregularities in the door you'll have leakage. Rubber type materials also conduct heat much slower than bronze.
Old 09-20-09, 12:04 AM   #5
Christ
Garage doors that open to the inside, I just tack the weatherstrip right to the perimeter of the door so it's sealed against the inside of the door jamb. I'm not sure if this is optimal, but it sure stops those cold breezes.
Makes the inside of the door look like crap, though... If the door opens outside, you put the weatherstrip either on the outside of the door, or on the inside surface of the jamb.
If anyone needs something to illustrate what I mean, I can show a bad drawing or something.
Old 09-20-09, 03:18 PM   #6
Higgy
The Gardener
I think I know what you mean but I'm not positive I follow. If you could throw up a drawing I'd appreciate it.
Old 09-20-09, 07:51 PM   #7
Christ
BY the way, I didn't mean roll-up doors, I mean man-doors.
Notice how the door seams are covered by the weatherstrip, applied to the door jamb/frame all the way around the door. This prevents drafts.
Old 09-23-09, 04:37 PM   #8
Higgy
The Gardener
Ya, I figured you meant man-doors.
Hmm...that's a good idea. I mean, when it's closed you wouldn't see it so who cares. As long as it does the job.
Thanks man.
weatherstripping
