Old 01-03-16, 05:23 PM   #331
OK....
Going through the code, and trying to find why it doesn't compile, you had an unterminated comment which I removed and a "booger" which was a single quote mark hanging out in space, which I also removed.
Here is your code with those errors removed:
Code:
  * General Purpose Controller for a water-to-water heat pump, basic version)
  * Provides for:
  *     2 minute startup dalay for compressor protection
  *     Temperature monitoring of:
  *         Evaporator HX temp
  *         Storage Tank Temp
  *     Controlling line voltage power to appropriate components:
  *         Outside loop pump
  *         Inside loop pump
  *         Compressor
  *         NOTE: Indoor operation is assumed, no compressor crankcase heater.
  * PIN ASSIGNMENTS:
  * Digital Pins:
  *    D0 (reserved for USB & serial communication RX)
  *    D1 (reserved for USB & serial communication TX)
  *    D2 (* reserved for input loop flow data *)
  *    D3 (* reserved for output loop flow data *)
  *    D4 user input request for heat
  *    D5 output to Compressor SSR
  *    D6 output to Inside Loop Pump SSR
  *    D7 output to Outside Loop Pump SSR
  *    D8 output to Auxillary Output SSR
  *    D9 (* not used *)
  *    D10 (* not used *)
  *    D11 (* not used *)
  *    D12 (* not used *)
  *    D13 LED (onboard)
  * Analog Pins:
  *    A0  input Temperature of Evaporator HX
  *    A1  input Temperature of Condenser Tank
  *    A2 (* not used *)
  *    A3 (* not used *)
  *    A4 (* not used *)
  *    A5 (* not used *)
#define  One_Sec              1000
#define  Quarter_Min         15000
#define  Half_Min            30000
#define  One_Min             60000
#define  Two_Min            120000
#define  Startup_delay      Quarter_Min
 float temp_in_celsius_0 = 0,
       temp_in_celsius_1 = 1,
       temp_in_kelvin_0 = 0,
       temp_in_kelvin_1 = 0,
       temp_in_fahrenheit_0 = 0,
       temp_in_fahrenheit_1 = 0;
 // Associating Variable Names with pins
 int HeatDemand = 4;
 int Compressor = 5;
 int inPump = 6;
 int outPump = 7;
 int auxOut = 8;
 int LED = 13;
 void setup()
// Setting the mode of the digital pins
pinMode(HeatDemand, INPUT);
pinMode(Compressor, OUTPUT);
pinMode(inPump, OUTPUT);
pinMode(outPump, OUTPUT);
pinMode(auxOut, OUTPUT);
pinMode(LED, OUTPUT);
   // Initialize print
   Serial.begin(115200);
// ****************** Startup Delay to Protect Compressor ********************
   Serial.print("begin startup delay");
   delay(15000);
   Serial.println(", end startup delay");
// ***************************** End Startup Delay ***************************
  Serial.print("Activating Compressor");
  digitalWrite(Compressor, HIGH);
  delay(5000);
 Serial.println(", Deactivating Compressor");
  digitalWrite(Compressor, LOW);
  delay(500);
 Serial.print("Activating inPump");
  digitalWrite(inPump, HIGH);
  delay(5000);
 Serial.println(", Deactivating inPump");
  digitalWrite(inPump, LOW);
  delay(500);
 Serial.print("Activating outPump");
  digitalWrite(outPump, HIGH);
  delay(5000);
 Serial.println(", Deactivating outPump");
  digitalWrite(outPump, LOW);
  delay(500);
 Serial.print("Activating Auxillary Output");
  digitalWrite(auxOut, HIGH);
  delay(5000);
 Serial.println(", Deactivating Auxillary Output");
  digitalWrite(auxOut, LOW);
  delay(500);
// Serial.println("starting loop");
   //Reads the input and converts it to Kelvin degrees
   temp_in_kelvin_0 = analogRead(0) * 0.004882812 * 100;
   temp_in_kelvin_1 = analogRead(1) * 0.004882812 * 100;
   Converts Kelvin to Celsius minus 2.5 degrees error
   temp_in_celsius_0 = temp_in_kelvin_0 - 2.5 - 273.15;
   temp_in_celsius_1 = temp_in_kelvin_1 - 2.5 - 273.15;
   //Converts Kelvin to Celsius minus 2.5 degrees error
   temp_in_fahrenheit_0 = ((temp_in_kelvin_0 - 2.5) * 9 / 5) - 459.67;
   temp_in_fahrenheit_1 = ((temp_in_kelvin_1 - 2.5) * 9 / 5) - 459.67;
   //Print the temperature in Celsius to the serial port
   Serial.print("Celsius_0: ");
   Serial.print(temp_in_celsius_0);
   Serial.print("Celsius_1: ");
   Serial.println(temp_in_celsius_1);
   //Print the temperature in Fahrenheit to the serial port
   Serial.print("Temp_0: "); Serial.print(temp_in_fahrenheit_0);Serial.print(" deg.F"); Serial.print(", Temp_1: "); Serial.print(temp_in_fahrenheit_1);Serial.print(" deg.F");
   Serial.println();
 void loop()
  if (HeatDemand)
  {outPump = true;
   if (temp_in_fahrenheit_0 > 34)
    {compressor = true;
      if (temp_in_fahrenheit_1 > 90)
        inPump = true;
      else
        inPump = false;
        delay (Half_Min);
    else
      compressor = false;
      delay ( Half_Min);
  else
    {compressor = false;
    while(temp_in_fahrenheit_1 > 90)
      delay (One_Sec);
    inPump = false;
    while (temp_in_fahrenheit_0 <34)
      delay(One_Sec);
    outPump = false;
 delay(Two_Min);
There are further errors in that you are using compressor in two different ways. First you define it as an integer and assign it a value of 5, then you are trying to use it as a true/false indicator.
I think if that part is fixed, it may well compile.
Give it a shot, we're getting close.
Old 01-03-16, 06:12 PM   #332
I didn't do the compressor deed. It is defined in comments as a digital output on pin d5. If this is bad syntax, then inpump, outpump, and compressor outputs are all called incorrectly. I just pasted the logic tree (based on the flowchart) into the loop.
In that case, you can substitute digitalwrite commands in where I set variables. For example, where I set outpump true, you should substitute it for digitalwrite(outpump, true) or digitalwrite(outpump,high). That should fix my wrong approach.
Don't forget to copy and paste variable names and capitalize stuff. The arduino ide is rather archaic in this respect, just like the indeterminate comments you spoke of. I actually pasted your code into a c++ editor to add my code into the loop. I haven't used a code editor as lacking in substance since the early 80's. It really is painful to use. One wrong move and you're dead.
