Old 08-02-17, 05:15 PM   #631
antdun
Originally Posted by pinballlooking View Post
Post a picture of your install.
I look forward to your production numbers.
I just posted about my installation here http://ecorenovator.org/forum/solar-...html#post55119 and that post has some pictures of my installation.
DIY installed a 9.98 kW rooftop solar system with REC TP2 panels, SolarEdge SE7600a-us grid tie inverter, power optimizers, & Snap 'N Rack mounting system.
antdun is offline   Reply With Quote
The Following User Says Thank You to antdun For This Useful Post:
pinballlooking (08-02-17)
Old 08-11-17, 07:15 PM   #632
nokiasixteth
Cant wait until i can wake the 10 kw sleeping giant from shaded pallet onto my roof like watching this post
nokiasixteth is offline   Reply With Quote
Old 08-11-17, 07:32 PM   #633
Robaroni
Robaroni's Avatar
It gets better, the thrill of diving an EV you charge from that 10k system. But wait until you get over the excitement of watching that meter spin backwards. That takes awhile!
Rob
Old 08-12-17, 11:20 AM   #634
where2
DIY Geek
I still smile when I look at my TED 5000 in the kitchen and see the PV array generating more than the house is using (meaning my meter is "spinning backwards"). Not sure that ever gets old.
Old 08-14-17, 12:46 PM   #635
celblazer
Ah I'm not the only one still running a TED 5000. Who knew. LOL Love seeing negative numbers, I'm at $-.73 today for usage. August bill projected $15 and dropping. Last month due to heat and rain my bill was $65 save $135 with solar.
celblazer is offline   Reply With Quote
Old 08-21-17, 04:31 PM   #636
pinballlooking
pinballlooking's Avatar
Default Solar eclipse as seen by my solar array.
We were in the direct path of the solar eclipse. My wife and I went into the swimming pool floated on our back put on out glasses and watched then eclipse. It was amazing experience.
But here it is as seen by my solar array.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 08-22-17, 11:24 AM   #637
antdun
Default Eclipse Power Production Dip
My home was at 90% eclipse coverage and this is what my daily output looked like.
Name:	Solar Eclipse Effect.jpg
pinballlooking (08-22-17)
Old 09-03-17, 06:49 AM   #638
pinballlooking
12.5 kW array we generated 1,717 kWh August 2017
We made 141 more kWh than we used. My oldest son is learning to drive in the Volt so we charged the car more this month than normal.
August 2017= 1,717 kWh
August 2016= 1,716 kWh
August 2015= 1,873 kWh
August 2014= 1,915 kWh
Highest one day August 2017 = 79.1 kWhs
Our system lifetime production is 83 MWh
We used 97 Kw more than we made.
We have 1,223 Kw banked for the winter.
We have drove our car more this summer and used more power.
Other solar producers show us your numbers for August when you have them.
EV Chevy Volt -
Old 10-03-17, 08:56 PM   #639
pinballlooking
12.5 kW array we generated 1,728 kWh Sept 2017
We made 296 more kWh than we used.
Sept 2017= 1,728 kWh
Sept 2016= 1,662 kWh
Sept 2015= 1,475 kWh
Sept 2014= 1,371 kWh
Highest one day Sept 2017 = 79.1 kWhs
Our system lifetime production is 74.5 MWh
We made 296 Kw more than we used.
We have 1,529 Kw banked for the winter.
Other solar producers show us your numbers for Sept when you have them.
EV Chevy Volt -
Old 10-04-17, 12:00 AM   #640
MN Renovator
MN Renovator's Avatar
3.36kw system
September 2017 377kwh
43kwh purchased from the utility, the air conditioning ran 77 hours in September, using roughly 2.3-2.5kw most of the time, usually this is an easy month to overproduce because the AC almost never runs but it was hot and the air was very wet.
