Advanced Search |
02-24-21, 08:49 AM | #13 |
7 ½ years ago I build this charger (EVSE). I now have a Gen2 Volt but the charger is still charging my car just fine.
I did add a couple vent holes in it since it is installed indoors. It just keeps the heat from building up inside the enclosure.
The Following User Says Thank You to pinballlooking For This Useful Post: | where2 (03-01-21) |
