Old 12-18-16, 09:34 AM   #501
kose2ik
goo.gl/photos/q9qbB3eYCddpJHAR7
(Estonia lng.) ehitusfoorum.com/viewtopic.php?f=10&t=57499
kose2ik is offline   Reply With Quote
The Following User Says Thank You to kose2ik For This Useful Post:
Piwoslaw (12-18-16)
Old 12-18-16, 02:21 PM   #502
Originally Posted by kose2ik View Post
A clear HX core? If you also made the outer casing clear you could observe what is happening inside - condensation, mildew, clogging, etc.
The Following 2 Users Say Thank You to Piwoslaw For This Useful Post:
AC_Hacker (12-18-16), kose2ik (12-18-16)
Old 01-24-17, 01:13 PM   #503
1234enough
Default Cooker hood exchanger
This is my first post on here, so may go wrong!!!
Thinking of air to air heat exchanger for cooker hood, anyone got experience of cleaning the twin wall plastic signage type of heat exchanger in this application?
1234enough is offline   Reply With Quote
Old 01-29-17, 09:43 PM   #504
DEnd
Due to grease buildup this is not a good idea, and may actually be illegal, just vent it directly outside. Yes you are losing some efficiency, so keep your stove small, use a multi-speed hood and only use the speed needed to vent the vapors.
If you don't really cook a recirculating range hood may be an acceptable solution, but I personally loathe them. Recirculating Range Hoods
Old 02-02-17, 10:12 PM   #505
Drake
DIY Guy
Default Long tube in tube DIY xchgr
Came across a Utube vid by Tom Heylen 'DIY air heat exchanger - PVC pipe and soda cans' who has built very much what I was thinking of designing. VERY lo-tech, affordable design. With a 35' basement ceiling run I have it should have provide a fairly HE counterflow heat recovery and larger air flow volume It should be much harder to frost plug.
The Following User Says Thank You to Drake For This Useful Post:
jeff5may (02-07-17)
Old 02-06-17, 10:24 AM   #506
Looks great!
Be sure and take lots of photos to share.
Old 02-06-17, 11:32 AM   #507
Default Installing a Single Room Energy Recovery Vent
Daox (02-08-17)
Old 02-07-17, 06:39 AM   #508
Default 3-D Printed HX Core
HERE
Old 02-08-17, 05:31 PM   #509
That is a very cool design! I really like the idea of using straws as they are so thin.
Old 02-09-17, 01:48 PM   #510
On Marsden's unit, air was brought in, then the fans reversed, and inside air went out through the same unit.
We have seen other units that use a similar principle using mechanical reversing.
The idea is producing very high COPs.
erv, heat recovery, hrv
