08-17-11, 07:47 AM | #1 |
heres a point of reference.
i have a 48v 20" battery powered push mower by ryobi. i live on .63 acres of land. one battery charge lasts for half of my yard. the grass is not too thick, roughly 1 hour of use. side discharge. no self propel use. the battery takes 12 hours to charge. ryobitools.com/catalog/outdoor_products/mowers/RY14110 |
08-17-11, 08:40 AM | #2 | |
08-17-11, 11:01 AM | #3 |
08-17-11, 09:26 PM | #5 |
20Ah batteries are only like $35. Unless you're looking for real long run times it shouldn't be that much for batteries.
08-23-11, 07:48 AM | #6 |
Well, I've started collecting parts for the project.
Over the weekend I picked up a 300W 24V scooter motor for $30 shipped off ebay. I'm really hoping this is large enough to spin the blade and cut grass. I think it might be a little on the small side, but the price was right and I couldn't pass it up. If its too small I'm sure I can find another use for a 300W permanent magnet motor. Last night I picked up the mower for the project too. Its my uncle's 20 year old Honda push mower. He recently replaced it with a reel mower since the engine was making odd sounds. Its a bit on the heavy side I think, but it should work. One downside is it doesn't have a side discharge. Its really only setup for bagging which I have no interest in using a bagger. So, I'll have to make something up for side discharge. Pictures to come. I'm still looking for suggestions too. I'd still like to keep the build price under $150 but exceeding that a little is okay too.
08-23-11, 07:55 AM | #7 |
Infrequent noob
I'd just put a plate on the discharge and let it mulch. As long as you don't let the grass get too long, shouldn't be a problem.
Do you know the eBay motor's physical size? FYI, the motor in my B&D M3300 mower is ~3.5 inches diameter by about 5 inches.
08-23-11, 08:50 AM | #8 |
I'm not sure of the exact size of the motor. It looks to be more like 4-5" in diameter and 3-4" long. I'll take measurements when it gets here.
I thought about the mulching option, but I would think it takes more power to mulch? I'd like to keep the power usage as low as possible.
08-23-11, 08:59 AM | #9 |
Infrequent noob
True. All depends how long you let the grass grow & how wet it is.
That's the biggest problem with estimating run time on a mower: the grass is a huge variable.
08-23-11, 08:31 PM | #10 |
As some of you know I have my own battery powered mower in the works. I have the motors mounted and have done some testing.
I am using motors form a Yardworks cordless mower, 20" cut, 24volt with 2- 12volt 17amp/hr batteries, that's what it was made with when new. Tests> I wanted to know how many amps one of these motors draws with the blade on spinning free not cutting any grass. Found that the motor at 24volts draws about 20amps, my amp meter is not the best. Picture shows the reading I got, the needle at start up goes higher then falls back to what you see. Thought this might be useful as a point of reference. |
Tags |
battery, cordless, diy, mower |
