Go Back   EcoRenovator > Improvements > Biofuels
View Poll Results: How much do you spend for hot water and home heating?
Less than $500 5 26.32%
$500-$1000 9 47.37%
$1000-$2500 4 21.05%
more than $2500 1 5.26%
Voters: 19. You may not vote on this poll
Old 04-23-11, 10:06 PM   #11
go4haudio
Default 18 months Hot Water in Portland, Oregon
This site claims to have had 18 months continuous hot water from this system. It might be appropriate for some people. I still think a good digester is better. Composting greenhouse provides hot water (original) - Appropedia: The sustainability wiki
go4haudio is offline   Reply With Quote
Old 04-24-11, 10:49 AM   #12
skyl4rk
I spent a few hours reading the site: High-Performance HeatGreen Home Heating System Version 3a and am quite impressed by the thought behind this system. Unfortunately there is no synopsis that explains the system in a few paragraphs. I will try to do so here:
Composting Bioreactor
The HG 3a composting system is a bioreactor designed to maintain composting at temperatures of 125F to 150F, which is the range of thermophiiic bacteria. The bioreactor must be held within that temperature range, requiring cooling to remove heat. A small amount of air must be provided to supply oxygen to the bacteria. One of the outputs of the bioreactor is heat, which can be removed by air cooling and water cooling. The reactor also produces carbon dioxide and water vapor.
Purpose
The purpose for building a reactor is typically for home heating or greenhouse heating using waste materials. The HG 3a bioreactor has a PVC coil water loop, which can be used for hot water hydronic heating, or potable hot tap water use. There is also an air cooling blower which outputs hot air. Apparently there is little to no odor in the exhaust air, although there is CO2 and water vapor as part of this exhaust air. Other uses for the bioreactor could include water distillation and cooking.
Bioreactor Vessel
The HG 3a system is designed to fit through a doorway, the main part is 2 feet wide by 5 feet high. It is a cylindrical tank made of plywood and designed to be rotated about a 3/4 turn (back and forth) approximately every hour. The tank is insulated with construction foam. Its function is somewhat similar to a front loading washing machine that you would typically see at a laundromat. The vessel is made watertight by lining it with a polytarp. There is an access door and ports for air intake and exhaust, as well as water connections for the loop of PVC tubing inside the tank.
Operation
The unit is fed with organic matter, which can be leaves, lawn clippings, chipped wood debris, agricultural waste (corncobs, straw) or agricultural products (hay, corn). The material must be kept dry until added to the bioreactor. Water is added to moisten the material. The amount of heat produced depends on the amount of material added, the fineness of the material, the condition of the bacteria, and the type of material. Once the bacteria are active and the bioreactor is at operating temperature, material is added daily or every few days to maintain the bacteria life cycle. There does not appear to be much waste material produced by the bioreactor, removal of waste material is not mentioned, although it is likely that the vessel must be cleared of waste at least once a season. It is unclear whether the bioreactor can be located outdoors. Examples shown appear to be in a garage or workshop location.
Bacteria Requirements
In order to promote bacterial digestion of the material, the bacteria require the proper temperature, oxygen, moisture and the food source material.
Temperature Control
Maintaining the proper temperature appears to be the most critical issue, because the thermophilic bacteria die when outside of their temperature range. Overcooling of the system by blowing cooling air through the system too long is one way to kill the bacteria. Another way to kill the thermophilic bacteria is to allow the system to overheat above about 170F. Water cooling using the PVC water loop would be another way to cool the vessel, which is not discussed in the article.
Oxygen
Generally the air cooling system provides enough oxygen for the bacteria. Tumbling the digested material by turning the tank hourly assist in getting oxygen to the bacteria.
Moisture
Water is added initially to the vessel to bring the material to "damp sponge" consistency. It is unclear whether additional water is required with each addition of material, or if water produced as a byproduct of digestion maintains the appropriate moisture level.
Food Source
It appears that the food source can be any compostable material. This would indicate a need for a balance of carbon and nitrogen, often discussed as a mixture of "green and brown". A discussion on composting principles is available here:
Fundamentals of Composting: Why Compost
From the discussion, it would appear that a home could be heated using autumn leaves and grass clippings. The author states that 1 acre could provide enough material to heat a home. The material would need to be dried to preserve it through the winter, which could be done using methods similar to agricultural practices used for hay and straw. For example, cut grass when the weather is predicted to be dry, let it lay on the ground in the sun for a day or two, collect it when dry. It may be convenient to press the dry material into blocks to aid in filling the bioreactor and to preserve the material. I do not have any data to back this up, but the amount of feed material required for one winter might be an uncompressed amount of leaves and grass clippings the volume of one or two mini-vans(?).
Conclusion
A composting bioreactor should be able to heat a home with a homeowner effort similar to a woodstove. Only minor additional energy inputs (blower) are required to operate the bioreactor. In wooded areas, high volumes of autumn leaves as a feed material are available at no cost and are currently collected as waste. Automation of the bioreactor should be fairly simple with an Arduino type controller. The vessel could be constructed for about $200 as shown in the article, or $400 with automation.
skyl4rk is offline   Reply With Quote
The Following 2 Users Say Thank You to skyl4rk For This Useful Post:
AC_Hacker (04-25-11), Daox (04-26-11)
Old 04-25-11, 11:26 PM   #13
Originally Posted by skyl4rk View Post
...Unfortunately there is no synopsis that explains the system in a few paragraphs. I will try to do so here...
Quite a good synopsis, I'd say.
Old 04-26-11, 11:49 AM   #14
skyl4rk
Something interesting...
When using large amounts of leaves to compost, you need to add a material with nitrogen to get the optimum food source for the bacteria. One way to do this would be to add manure.
Composting toilets could better be called Dessicating toilets because they are designed not to compost so much as to limit odors by drying the materials. A basic design principle for composting toilets is urine separation from solids. A simple composting toilet is a pail with a strategically placed funnel to drain urine away while collecting solids. The solids are covered with peat moss or similar dry material, which helps dry them out.
The dry products of a composting toilet would be an advantageous addition to a composter using mainly dry leaves. Since the bioreactor is designed to run hot, it would likely kill pathogens more quickly than a normal manure pile. So you could solve the problem of sewage disposal, heat your home and create a fertilizing compost product for the lawn. Low impact permaculture.
Here are some interesting links I came across...
XACT BioReactor: Composting System | Cuff Farm Services
Earth Tub - Green Mountain Technologies
(WO/1999/067191) A BIOREACTOR FOR COMPOSTING
http://conference2005.ecosan.org/pre...ns/hanssen.pdf
I don't think any of these bioreactors are as good of a design as the HG 3a system.
Old 04-26-11, 03:23 PM   #15
strider3700
I've been gardening for 6 years now and have had a compost pile since the beginning. Not once have I ever got it hot enough to make a difference heating water. the best I've managed to do is get it to feel warm to the touch. Hot compost piles are not trivial to make.
Old 04-28-11, 05:05 PM   #16
skyl4rk
Do you think that this bioreactor is a feasible design?
Old 04-29-11, 05:51 PM   #17
strider3700
I've seen backyard scale rotating composters for sale now and again. the people always swear that they work great but most quote 2-3 weeks not 4-7 days. I'm happy with my free pallets with a pile in the middle so it hasn't been a big issue.
Old 04-29-11, 08:34 PM   #18
skyl4rk
I talked with the city manager, he said I could have as many leaves as I wanted for free. They use a vacuum truck with a container 24 feet by 8 feet, and 6 feet high. The leaves are run through a big squirrel cage blower, thats what vacuums them up from the street. So they are cut up a bit. I looked at the piles from last year, they seemed to be warm and wet, but it rained a lot yesterday.
With an unlimited supply of leaves, I could just do the loops of pvc pipe in a pile of leaves. However, I don't have a lot of room in my yard. I have room next to my garage for maybe one truck load of leaves, and could fence it in so no one would see it.
I'm not sure if I am going to do this as a project yet, but the bioreactor compost bin looks pretty interesting and would be fun to see if I could get it to work.
Old 05-04-11, 07:13 AM   #19
NeilBlanchard
NeilBlanchard's Avatar
Sewer pipes are a great heat source:
Old 10-18-20, 06:45 AM   #20
IamIan
IamIan's Avatar
FYI
Basic videos of my first 3 experimental steps.
Eventually , the goal would be to work up to a supplemental home heat source. Ideally fueled by free to me waste products I already get. Mostly high carbon things like leaves in the fall , junk mail , cereal boxes , etc .. Also ideally with nearly the same input effort from me , just effort applied differently.
Steps 1 & 2 Video
#1 = 4 gallon container in basement (~0.02yr^3)
#2 = 6 containers ~40 gallons each in basement (6 @ ~0.2yr^3)
https://youtu.be/dRHOkPpzCaM
#3 = Data results how #2 did over time.
https://youtu.be/3FgEVvwl7cU
#4 = will be roughly ~3yr^3 bin outside .. ~5ft dia ~4ft tall
I think I'll have just enough 'fuel' accumulated .. to fill/fuel step #4 by combining what is left from #2 , a full years worth of paper goods , and the leaves should fall soon here the end of October also.
From the research I've done on this subject .. It seems common , to be able to get up in the 5,000 BTU/hr to 10,000 btu/hr range for 3-5 months , usually requires about a 30 to 40 cubic yard compost pile (6000 to 8000 gallons) , with good aeration , moisture , etc .. I don't know if I'll ever go that big , but well see what the data says along my journey.
IamIan is offline   Reply With Quote
