Old 08-02-10, 06:27 AM   #41
Looks like a nice unit!
Do you have a version that can handle an AC pump?
bsmith (08-02-10)
Old 08-02-10, 08:29 AM   #42
bsmith
Cheap DIY'r
Its got 10A output relays that should work for that applications. I would keep the pump below 4-5A for AC version and would probably advise to put a MOV in parallel with the relay contacts. You always connect an external contactor to the unit if you wanted something beefier.
bsmith is offline   Reply With Quote
Old 08-02-10, 04:02 PM   #43
tasdbois
How about this?
tasdbois is offline   Reply With Quote
Old 08-02-10, 05:58 PM   #44
bsmith
Cheap DIY'r
That looks like a DC switch to me since its for cars maybe. You would probably be better off with the 10A relay contact unless your load is DC.
Old 08-02-10, 08:06 PM   #45
bergenm
Eco-Geek
bergenm's Avatar
Send a message via AIM to bergenm
This gizmo works great on a taco 009 taco pump 120v@1.2A controlled by 3.3v I/O pin.
10A @ 480VAC SOLID STATE RELAY-MPJA, Inc.
bergenm is offline   Reply With Quote
The Following User Says Thank You to bergenm For This Useful Post:
bsmith (08-02-10)
Old 08-02-10, 08:13 PM   #46
bsmith
Cheap DIY'r
That looks pretty good and the price is right.
Old 11-17-10, 09:40 PM   #47
bsmith
Cheap DIY'r
Here is a nice differential temperature controller with temperature logging and 4 inputs for $60. myDTC Differential Temperature Controller Store - Home
Brian
Old 02-23-15, 02:31 PM   #48
house4u
Hi to all. I have made free Arduino's solar controller. I am from Ukraine and tried to translate all instruction. Maybe translation was done not so good but i was trying. I think now, everybody may to do thermal differential controller by yourself!
Of-course i cannot post links for now... Also i have interesting online monitor page of my home-made hot water solar system, but it is not in english. I may try to translate it too.
house4u is offline   Reply With Quote
Old 02-24-15, 06:00 AM   #49
house4u
Now i can post links. I have created a separate thread for my solar controller here http://ecorenovator.org/forum/applia...4u-viktor.html
Old 06-11-15, 06:02 AM   #50
house4u
Now i am working in this direction. For example i plan in few next month to release new firmware (cost $4.95) with WEB Monitor function, so everyone will be able to have similar monitor.
But this WEB-monitor needs a separate web-server to work, so i am going to provide my own web server with $0.95 per month or $9.95 per year. And of course - the same firmware for hot water solar controller is and will be free (without web-monitor function)
controller, diy, hot water, solar
