Old 01-02-20, 09:52 AM   #21
Here the table cutting ½” steel plate. I am making magnet holders for lifting steel plate with two 880 pound magnets to help load the table.
I need to level the table and I will be raising the water level once I level the table.
1/2" Thermal Dynamics 60i
https://youtu.be/-iMxUaujFP0
The 2" by 1/4 square tube will allow the magnets to be spread apart 4'.
Then it will go on my forks to make it for simpler loading thick steel plate.
Daox (01-02-20)
Old 01-02-20, 10:13 AM   #22
WyrTwister
Do you have to use an air dryer , on the compressed air going to the plasma cutter ?
Wyr
God bless
Old 01-02-20, 11:05 AM   #23
My compressor has an auto drain on a timer. I made a copper air cooler with drain valves. Then that goes into an air dryer. Then a one-gallon desiccant dryer and a motor guard filter.
3/4" rapid Air connecting it all together.
The dryer the air the better the cut and the longer consumables last.
I may add a air cooler at the compressor after the pump before it enters the compressor. I am going to wait to see if I think it is needed.
ID:	8794   Click image for larger version
Old 01-02-20, 11:25 AM   #24
WyrTwister
How warm is the air , after it leaves the copper coil ? Winter ? Summer
Wyr
God bless
Old 01-02-20, 11:39 AM   #25
The compressor is 80 gallons Emax I just got it powered up the other day.
I don’t know the temps yet with this new setup for my plasma table.
Out of the compressor is 3/4 black iron pipe. That goes to the copper.
My 3/4 regulator seems to react to slow. I think I need a better one.
I will be checking the temperatures. It is cold right now but summer heat I am sure I will make lots of water.
Old 01-03-20, 07:35 AM   #26
WyrTwister
I was thinking , if the discharge temperature gets up , you might put a box fan blowing on the copper coil ?
Wyr
God bless
Old 01-03-20, 09:46 AM   #27
What I see people doing is adding a transmission cooler after the pump. Set it up to use the compressor fan to draw air through it.
Kind of like this.
I had a auto drain to do this but the one they sent me just did not work.
I am sending it back today.
Does anyone know a good one?
Old 01-03-20, 11:03 AM   #28
WyrTwister
A transmission cooler would be a good idea if it is rated for the pressure .
Wyr
God bless
Old 01-06-20, 01:40 PM   #29
I cut some ½” plate to build a magnet holder.
This is to help load my table.
This is straight off the table.
ID:	8797   Click image for larger version
ID:	8798   Click image for larger version
Old 01-07-20, 01:07 PM   #30
That looks like some pretty heavy stuff!
