Old 02-19-09, 10:11 AM   #21
bennelson
Home-Wrecker
Hey Tim,
Make sure to post some pictures of your loot so we can see what you got!
My goal for the year is to get off gasoline, and that includes mowing lawns.
Reel mowers behind the Citicar keeps getting more intruiging.
Old 02-19-09, 10:15 AM   #22
I've really been slacking in the pictures department. I meant to post about the batteries early this week and didn't even pull them out of my car until mid this week. Oh yeah, the batteries came with nice trays even!
Old 02-20-09, 06:14 AM   #23
Alright, here is what I all got.
Motor, controller (top), wires, potbox and contactors in the bin.
Motor tag and ratings. I'm glad its rated for more than 1700 rpm.
The motor has two extra wires comming out of it. Tom thought this was probably either for a temperature sensor or rpm output.
The removable foot mount. I think I'm going to take it off and try to face mount it. There are no tapped holes in the end, so I'll have to disassemble the motor and drill and tap some holes.
Its just about 7 inches in diameter.
ID:	109   Click image for larger version
ID:	110   Click image for larger version
ID:	111   Click image for larger version
ID:	112   Click image for larger version
Old 02-20-09, 06:18 AM   #24
The motor looks just over 8 inches long.
Here we have the box of contactors.
And here we have the fork lift controller and pot box.
Of course I couldn't resist a trial fit.
These are the batteries I got. They're about half the size of a motorcycle battery and are rated at 7 Ah.
ID:	114   Click image for larger version
ID:	115   Click image for larger version
ID:	116   Click image for larger version
ID:	117   Click image for larger version
Old 02-20-09, 06:21 AM   #25
The batteries even came with these nice battery trays.
That about does it for parts. The next step will be finding pulleys for it. The two shaft extensions are different diameters, so we'll see which one its easier to find pulleys for. I've was told I can go down to the local farm supply place and pickup hubs that you just bolt different size pulleys to, so I'll probably try that out. After I have that sorted, I'll look at mounting the motor.
Old 02-20-09, 08:25 AM   #26
MetroMPG
Infrequent noob
Nice haul! Christmas came early (or late) for the project.
Old 02-20-09, 03:12 PM   #27
While we're at it. Anyone got some good suggestions on color schemes? I kinda like the Simplicity colors, but I'm open to suggestions.
Old 02-20-09, 08:45 PM   #28
Higgy
The Gardener
You strike me as someone who likes...pink...with flower decals.
Old 02-25-09, 10:45 AM   #29
davidbr13
That's awesome! Haven't been around here for a while, but just dropped back in to ecorenovator and found this cool project. Gotta say finding a motor is the hardest part. If the one you have is permanent magnet, don't bother with a controller. Use a contactor and continue to use the transmission to change the ground speed. You'll just have to change voltage and/or pulley and belt sizes to get the same speed the Briggs had.
I've finally resigned to sandblasting my E15 elec-trak "basket case" myself and using regular paint (powder coating shops around here cost 3-10 times what they do in the rest of the country). I've got most of the parts, but have a LONG ways to go...I am trying to put together a restoration album, though.
davidbr13 is offline   Reply With Quote
Old 02-27-09, 08:08 AM   #30
Last night it was a bit warmer out and I took some time to work on the mower.
The first thing I did was take the motor apart. I want to drill and tap the face of the motor so I can just mount it flat against the mower frame. So, I needed to know if there would be enough material to screw into, and if the screws could protrude into the motor at all without hitting anything. The picture shows the flange that will be facing downward. I didn't measure the exact thickness, but it should be just fine.
The motor housing and brushes also looked in good shape. There appears to be plenty of meat left on the brushes. It also seems to be fairly clean.
ID:	122   Click image for larger version
ID:	123   Click image for larger version
ID:	124   Click image for larger version
conversion, electric, lawn mower, tractor
